BDP-2 Digital Player
0 Members and 1 Guest are viewing this topic. Read 653293 times.
Fernando
  • fernando _at_ -34.899705, -56.158880
Re: BDP-2 Digital Player
« Reply #1340 on: 9 Feb 2016, 03:03 pm »
Can Bdp-2 read cue files? I have many albums ripped into single files accompanied by cue sheets.  Bdp-2 interface seems to show the whole album as one song if it is ripped as one file.  Thx...
I have the same question. From experience I'd say it can not. Then, could it be made to read .cue files so as to show different songs instead of only one?
Fernando.
Krutsch
« Reply #1341 on: 9 Feb 2016, 04:53 pm »
Thumb drives are handy if you want to transport your music to a friends or elsewhere.  HDD is super cheap storage now....even SSD is reasonably priced.
And, thumb drives use less power, which is handy for BDP-1 owners.
ssnow
« Reply #1342 on: 13 Feb 2016, 03:24 am »
I am having about a 25% error rate with the tagging on the MPaD app while ripping CDs using the BOT-1. Although some of them are amusing in a bizarre kind of way, it is very frustrating to have a library of over 300 CD's and not really know what 1/4 of them really are. I was initially planning to rip over 1,000 CD's, but not with this error rate. I do not have the skills to manually go in and fix all these errors if there is even a way to do that. Is there a more reliable app or program that can be used with the BDP 2 and an iPad ? It was nice to have the free app, but this is virtually useless to me with an error rate this high
  • The Demo is Everything!
    • http://www.bryston.com
Fernando
« Reply #1344 on: 13 Feb 2016, 03:22 pm »
ozzy
« Reply #1345 on: 21 Feb 2016, 10:54 pm »
I have an external hardrive plugged into my BDP-2. I just replaced a failed hardrive. Luckily, I had it backed up.
Does the BDP-2 go into sleep mode?
I ask this because the hardrive still flashes after the Bryston screen goes blank.
unincognito
    • bryston.com
« Reply #1346 on: 21 Feb 2016, 11:03 pm »
The display turning off is simply a "screensaver" to prevent the display from prematurely dimming over time.
ozzy
« Reply #1347 on: 21 Feb 2016, 11:11 pm »
Chris,
Thanks so I would need to turn off the BDP-2 in order to turn off the hardrive?
unincognito
    • bryston.com
« Reply #1348 on: 21 Feb 2016, 11:33 pm »
Chris,
If it's powered off the USB cable that would do it, I'm a bit surprised though that it doesn't spin down on its own.
ozzy
« Reply #1349 on: 21 Feb 2016, 11:44 pm »
No the hardrive has its own power supply.
I'm not sure if it does spin down. The unit is not hot, but it still flashes.
Turing the BDP-2 off at night means it will take 15-30 minutes before I am able to access my music the next day.
Wapiti
« Reply #1350 on: 22 Feb 2016, 02:51 am »
15-30 minutes?
ozzy
« Reply #1351 on: 22 Feb 2016, 02:53 am »
yes, it seems to take about that.
unincognito
    • bryston.com
« Reply #1352 on: 22 Feb 2016, 05:42 am »
It may check for changes upon startup (this can be turned off), but your music should be playable immediately after the mpd ready message appears.
ozzy
« Reply #1353 on: 22 Feb 2016, 07:43 pm »
Well, the hardrive shows up fairly quickly but it takes about 15 minutes for all of my folders  to be available.
Rod_S
« Reply #1354 on: 22 Feb 2016, 10:21 pm »
Although not quite the same issue as you since as I use a NAS I've noticed after updating to the latest firmware it's taking considerably longer for all my folders to be picked up and it also takes a lot longer before the player will allow me to start playing music, even for the folders/files that are available quickly.
unincognito
    • bryston.com
« Reply #1355 on: 23 Feb 2016, 02:06 am »
If your using a NAS you should turn off the update database on startup, found under mpd settings.  You can always place the unit in service mode and email us the service id so we can see why your u it is always updating upon startup
Rod_S
« Reply #1356 on: 23 Feb 2016, 12:05 pm »
Thanks Chris, wouldn't this feature need to be on though to capture any new files added on the NAS? I frequently add new albums lately. If not I'll definitely set that to off and see how the start-up performance changes before having you connect and investigate.
unincognito
    • bryston.com
« Reply #1357 on: 23 Feb 2016, 02:20 pm »
There's a button in the upper right hand corner that does the same thing, just wait until the network share is mounted before using it.  Also if you go into NAS setup there are is a button that allows you to update an individual network share.  Finally there is an option found in media player that allows you to update an individual folder on the network share.
Fernando
« Reply #1358 on: 23 Feb 2016, 11:52 pm »
There's a button in the upper right hand corner ... (snipped).  Also if you go into NAS setup there are is a button ... (snipped).  Finally there is an option found in media player ... (snipped).
Very nice.
I assumed that this function had already been thoroughly foreseen, but I failed to understand how.
Not that I cared too much about it.
But I still get lost  :scratch:
Some screenshots may be helpful for me, and may be for someone else.
Fernando.
unincognito
    • bryston.com
« Reply #1359 on: 24 Feb 2016, 12:16 am »
There are screenshots and sections in the manic moose manual
http://www.bryston.com/PDF/Manuals/BDP-2_MM_Manual.pdf
