0 Members and 2 Guests are viewing this topic. Read 14307 times.
Peter, Welcome to AC. Please make sure you read the guidelines for manufacturershttp://www.audiocircle.com/index.php?topic=42858.0
BTW, Welcome Peter! Your input here will be very much appreciated by all, I'm sure.
If Audirvana on the Mac side will someday be able to support the full 768khz rate and upsample to that rate using the iZotope upsampling filter, there will potentially be a lot more happy Mac, NOS1 users.They may not be able to take full advantage of the "ultimate" sound quality provided by XXHighEnd; but how far will they be away from it? At this point that's a question which is impossible to answer. In any case they should get significantly better SQ than is available to them at the moment.
Peter, I believe you occasionally play files from a network share yourself or have in the past. Just how much of a hit does SQ take when you do this? I'm assuming no WiFi here. The PC running XXHighEnd is connected via ethernet. If you tried to put it in percentage terms does the SQ drop to 80%, 90%. What would you estimate in approximate terms?
IF someone (me) got off track because I got a wild hair from reading the next best computer setup is it easy to get back to where it was? Meaning, is there a config file that is saved and it's as easy as loading the previous config file? Or is it a bunch of knobs and buttons that are very hard to find that can take a while?
Also, is the PC that you sell, completely silent? My PC and HD's (AIFF) will be in the listening room.
Normally a software house large enough to develop a program as sophisticated as XXHighEnd would probably employ a team of professional chimps to stress test the software before it is even released to beta testers and this sort of problem would, hopefully, be picked up at the in house testing stage. We can't expect one man to do all of this!
Just wanted to point out to folks what they'd be getting into. Yes indeed anyone using XXHighEnd is effectively a beta tester and this is part of the adventure. There has not been what I would call a "stable version".
I would like to see a simplified streamlined version of XXHighEnd with all the sound quality features; but with a cleaned up interface and I have made a number of suggestions to Peter via private mail on this.
What are the odds of this happening.
my comment about XXHighend not meant for the masses was a general comment for people who might think XXHighend is easily usable by a computer novice; not as a response to your post.
right now i am pleased someone like peter is actually doing R&D to create Arc Prediction, true memory player and Phase Alignment DSP
geofstro, perhaps you and Peter could team up and be the Jobs and Wozinak of digital playback.
I own a Phasure NOS1 USB and I'm getting very impressive results with it used in combination with XXHighEnd. If you get XXHighEnd set up just right on your PC, you can achieve a rich/full bodied sound, with detail/High-Resolution at the same time. Too often these two qualities seem to be mutually exclusive. It all hangs on the ability to draw out the best from CD by upsampling standard CD rips all the way up to 705.6 or 768khz using his "Arc Predict" upsampling/interpolation filter.Unfortunately this "Arc Predict" filter is only available as part of XXHighEnd along with numerous settings that allow you to tweak the sound in an almost infinite number of ways until you achieve nirvana. That sound is also dependent on turning off various windows services which can hurt sound quality if they're running. WiFi is considered one major culprit. Fortunately these services can easily be turned off from within XXHighEnd and restarted again at another time when needed. This is about the most convenient option within XXHighEnd.Peter is always innovating to improve SQ and his latest feature, Phase Alignment takes the SQ even further, as long as you follow the advised precautions. SQ can also depend on exactly which version of Windows you're running and which updates you've applied. In short, XXHighEnd really puts the inconvenience back into digital.Unfortunately XXHighEnd is singularly the most frustrating piece of software it has ever been my displeasure to use Put one foot wrong and it'll have you tearing your hair out, as you'll be confronted with endless error messages which are of little help. Although there are highly cryptic, essay length tooltips which you won't often manage to read before they disappear.Peter is very forthcoming with advice on his forum; but unfortunately he is often patronizing to his users as a browse through some of the posts will clearly demonstrate. Personally, however good XXHighEnd and The NOS1 DAC are, I don't see any excuse for this behavior towards his customers.There is currently no way to get the full potential out of the NOS1 other than by using XXHighEnd. It will only work at above 384khz for upsampling with XXHighEnd and the all important "Arc Predict" filter is only available in there.If "Arc Predict" is really his own unique invention, along with some of the other features of XXHighEnd, I think it should be licensed out so it could be incorporated into user friendly and competently designed software such as J R Media Center and Peter would make a fortune. Someone else on CA has suggested this.In the time I've had the NOS1 it has performed faultlessly; but then again I don't think it really needs to do that much apart from convert digital at the sample rate it receives to analog. There are no upsampling or oversampling filters or filters of any kind within it, apparently, because it relies on all this being done in software. It seems to be competently designed. Mind you I've also had pretty amazing results using XXHighEnd with the Altmann Attraction DAC connected to the PC via a USB to s/pdiff converter upsampling to 176.4 or 192 for the Altmann.XXHighEnd is a major PIA to use; but I'm still soldiering on for now because of the SQ.I've tried to be as objective as possible.Hope it helps!Geoff
