Grado pin markings?
0 Members and 1 Guest are viewing this topic. Read 2286 times.
Grado pin markings?
« on: 28 Sep 2012, 09:44 pm »
I was wondering if anyone knows how the Grado markings translate to typical
1) white = left channel
2) blue = left channel gnd
3) red = right channel
4) green = right channel gnd
Grado uses these markings
            G
        L
              R
        H
I know the R/H and G/L are coils and have a guess, but I would rather have those in the know provide their information.
Thanks.
Mitsuman
  • Diamond Tone Junkie
Re: Grado pin markings?
« Reply #1 on: 28 Sep 2012, 10:04 pm »
The markings on the Grado are:
H - hot
G - ground
R - right
L - left
Each mark refers to the 2 pins on that side of the cartridge.
BTW, no reply to your same question on AK.  :wink:
Mitsuman
« Reply #2 on: 28 Sep 2012, 10:06 pm »
If that doesn't help, maybe this makes it clearer.
The two pins near the L are BOTH left channel and the two pins near the R are BOTH right channel.
Example: The pin between the H and the R is Right Channel Positive. Etc, etc, etc.
Wayner
« Reply #3 on: 28 Sep 2012, 10:14 pm »
Wayner
« Reply #4 on: 29 Sep 2012, 03:05 am »
Thanks Gents. Much appreciated.
Cheers.
« Reply #5 on: 29 Sep 2012, 02:05 pm »
Another quick question. What size allen wrench is needed to fit the screw (want to adjust the vta) on
the sme iii? I hate to risk taking the entire table to a hardware store.
Cheers and thanks.
Wayner
« Reply #6 on: 29 Sep 2012, 02:56 pm »
Buy a complete set, they aren't that much. I'd get the set that has them individually so you don't have to clunk the hole set around. Probably can get a set for $10 at ACE hardware.
The set usually goes from .050 to 1/4"
Wayner
« Reply #7 on: 29 Sep 2012, 03:25 pm »
Thanks Wayner. Since SME is British, will the wrenches be metric?
Cheers.
Wayner
« Reply #8 on: 29 Sep 2012, 05:41 pm »
British Unified Screw Thread standards are (for the most part) the same standards for US and Canada. However, that doesn't mean that they are not using metric threads. If I were to guess, I'd pick that they would use a #6 screw and if it is an allen type setscrew, would be 5/64.
Have you actually looked at the head? Many of my tables have a slotted head on the set screw that simply requires a small screw driver.
Big unknown here.
Wayner
« Reply #9 on: 29 Sep 2012, 05:59 pm »
Big unknown here.
Wayner
Hi Wayne,
No slot, and I was able to pickup a couple of metrics, they did not have any small american sizes on hand.
1.5mm is slightly to small while 2mm is too large so 5/64th won't work.
I am figuring 1/16", at 1.587mm, maybe just large enough to work.
Decimals, 1/16" is .0625 while 1.5mm is .0590
Now I have to find one.
Thanks Wayner for your time and help. I will keep everyone updated for future reference.
Wayner
« Reply #10 on: 29 Sep 2012, 07:23 pm »
I looked at the wrong column. Your set screw is almost for sure a #6, and it needs a 1/16" allen wrench, not 5/64 (which is for cap screws, my blunder). So now this should be a piece of cake for you.
The Machinery's Handbook comes in handy once in a while.
Wayner
« Reply #11 on: 29 Sep 2012, 07:34 pm »
Wayner
1/16" worked perfectly and all is a go.
Thanks Wayner.
