Bass traps behind panels
0 Members and 1 Guest are viewing this topic. Read 11622 times.
josh358
Re: Bass traps behind panels
« Reply #20 on: 22 Sep 2012, 04:39 pm »
The folks advised me that one pair of their QRD diffusors was sufficient for Magnepan 1.7s and advised 2 pairs for Magnepan 20.7s. I didn't see what your speakers are, but this should be helpful as a guide.
I use two since I had planned to upgrade to the 20.7s, but this has been postponed (shelved really).
Were these their 2 x 4 wooden diffusors, or the 2 x 2 plastic ceiling diffusors?
jk@home
« Reply #21 on: 23 Sep 2012, 12:07 am »
They are modded MMGs, 50" tall. I planned on also placing diffusors on the walls, close to the inside edges of the traps, where one would see the backs of the speakers if looking into a mirror on the back wall, from the listening chair.
So I am looking at 4 or 8 (or more?) - 2x2 panels, depending on the amount of diffusion required.
medium jim
« Reply #22 on: 23 Sep 2012, 12:12 am »
I'm probably all wet on this one, but I try to keep it clean behind the panels and only have some absorption behind them, mostly behind the ribbons. This seems to work the best for me, but again I may be all wet....
Jim
dm
« Reply #23 on: 23 Sep 2012, 03:01 am »
I have been happy with the GIK QRD's behind my magnepan 1.6.
see here:
http://www.audiocircle.com/index.php?topic=96511.msg978891#msg978891
rw@cn
« Reply #24 on: 23 Sep 2012, 03:15 pm »
These: http://www.gikacoustics.com/gik_qrd_acoustic_diffusors.html
josh358
« Reply #25 on: 23 Sep 2012, 11:16 pm »
OK, so they were the full sized ones. Did they suggest, when used with the 20.7, putting them on top of one another for 8' tall diffusors? Or side by side?
rw@cn
« Reply #26 on: 24 Sep 2012, 05:31 pm »
Side by side. Here is an older picture before I install corner bass traps, mye stand and cleaned up the wiring.
josh358
« Reply #27 on: 24 Sep 2012, 08:28 pm »
That's interesting. I suppose that's because of the width of the 20.7's, although most of that is woofer and I wonder whether the diffusors even do anything at those frequencies.
rw@cn
« Reply #28 on: 24 Sep 2012, 09:37 pm »
I had 3.7s in that same space and briefly tried using only one per side and thought that 2 per side was better. For some reason, I have not experimented with the 1.7s.
josh358
« Reply #29 on: 24 Sep 2012, 10:01 pm »
Interesting. I hate to think what that means for my Tympanis . . . :-|
berni
« Reply #30 on: 27 Oct 2012, 04:55 pm »
is there a Pathos InControl preamp? I have one as new for sale(2100 eur) :))
rw@cn
« Reply #31 on: 27 Oct 2012, 05:00 pm »
Yes that is a Pathos preamp. I just replaced it with a Pass XP 10. I wanted the XP 20 but couldn't quite stretch the budget that far. I'll be putting the Pathos on the market in a few weeks. I haven't decided on the price yet.
berni
« Reply #32 on: 27 Oct 2012, 05:11 pm »
How would you define the sound, very detailed, transparent and wide, but a bit thin on the low end so bit weak for planars..
bpape
    • Sensible Sound Solutions
« Reply #33 on: 27 Oct 2012, 05:17 pm »
I'm actually doing a room for a customer right now that is doing 5.1 system with 20.7's.  We're using 4 of the Q7D's behind each of them - 2 wide and 2 high.
Bryan
