RMAF new stuff, new stuff.... (pics on page 2)
0 Members and 1 Guest are viewing this topic. Read 83004 times.
Ric Schultz
Re: RMAF new stuff, new stuff.... (pics on page 2)
« Reply #220 on: 30 Sep 2012, 06:54 am »
I can see the tube connectors on more inexpensive stuff that people DIY.  You do have to reterminate your speaker wire with the tube male connector.......not such a big deal for those who are DIYers and make their own cables.  But people buying $20,000 speakers?  Most of these people already own speaker wires that are expensive and probably terminated with spades.  How are they going to use their speaker cables?  They cannot.
The tube connectors are not sonically better than the binding post bypass system.  The binding post bypass system allows you to use any spade or bare wire speaker wire and clamp it directly to the wire coming out of the speaker.  The only limitation of the binding post bypass system is you cannot use really large gauge wires coming out of the speaker to wrap around the outside of the binding post for the clamp.  The binding post bypass system can be used on amps too....same results....you cannot go back to any binding post.
However, a plastic or wooden clamping system is even more transparent.  Even the mass of the connector messes up the sound even though you are clamping the wires together......so the best thing is clamping without any metal.  A clamp system also allows the customer to also use Zobels, Ground Enhancers, Bybees, whatever, in conjunction with the speaker wires.
The picture below shows a cotton covered wire coming out of the amp through some grommets using very inexpensive binding posts.  This could be made to look mucho better for the serious money people.
« Last Edit: 30 Sep 2012, 08:17 am by Ric Schultz »
Danny Richie
« Reply #221 on: 30 Sep 2012, 01:38 pm »
How the heck do you pull this off with the Neo 3 rated at 93 dB/W sensitivity?? 96 dB for the 4 Neo10s makes sense though.
It's a custom version.
The male end of the Electra Cable tube connectors can easily be fitted to any speaker cable in just a few minutes. The tube connectors also accept a standard banana plug, but will obviously not sound as good.
The biggest problem I have seen in the past with the by-pass system is the often exposed bare wire. So after some time the connection quality is often compromised by oxidation. I am not saying this always happens, but it often happens. The second biggest problem with that being used in high end audio is the same as the biggest problem the tube connectors have faced. It is not audio jewelry.
HT cOz
« Reply #222 on: 30 Sep 2012, 01:45 pm »
Ahh just leave the wire hanging out with a pack of these
 :lol: :lol: :lol:
I wonder if you can find them in wood?
 :thumb:
Nick77
« Reply #223 on: 30 Sep 2012, 02:27 pm »
My speaker cables have spades on one end and banana's on the the other so the tube connectors worked out. I wasn't about to chop up my $1500 speaker cables, i agree this could be a issue for high end market. I'm sure the option of a high end standard posts would solve this issue.
Russell Dawkins
« Reply #224 on: 30 Sep 2012, 08:39 pm »
 :lol: :lol: :lol:
 :thumb:
That would probably work well, if done right!
I understand the best connection of all is proper wirewrap around a square post - better than solder.
Danny Richie
« Reply #225 on: 30 Sep 2012, 10:08 pm »
My thinking is the complete opposite. Why would I want to use a high quality $1,500 a pair speaker cables then degrade the sound with a spade or a banana plug if I didn't have to? New ends can be put on in about 20 minutes. And if you already have the ends...  A pretty significant tweak that cost nothing but a little bit of time, you bet!
Nick77
« Reply #226 on: 30 Sep 2012, 10:58 pm »
deleted
jtwrace
    • TIPP YouTube Channel
« Reply #227 on: 30 Sep 2012, 11:14 pm »
The problem that you have is that it completely devalues the cables.  Until you convince all the "high end" cables guys that Tube Connectors are the new standard, you will have an issue if you are really going to be selling these speakers for $20k. I highly doubt that most will chop them up for Tube Connectors.   :dunno:
persisting1
« Reply #228 on: 30 Sep 2012, 11:17 pm »
You can always send your cables in to get re-terminated by the factory. Not convenient, but much cheaper than new cables.
jtwrace
« Reply #229 on: 30 Sep 2012, 11:19 pm »
Yes, I know that.   :duh:  For instance, I'm not so sure that Cardas would even put them on though.
persisting1
« Reply #230 on: 30 Sep 2012, 11:25 pm »
I was under the impression that the tube connectors accepted banana plugs. You can have Cardas add those if you have spades or bare wire.
persisting1
« Reply #231 on: 30 Sep 2012, 11:33 pm »
jtwrace, you're right.
I feel your pain. If this hobby "allowed" me to be happy with my purchase and never needed to upgrade, then this wouldn't be a problem.
Milehighguy
« Reply #232 on: 30 Sep 2012, 11:39 pm »
I was thinking about this issue recently as I was contemplating puting together a N3S kit. Actually, I'm hoping to have the Skiing ninja do the work as soon as I get some spare change. Anyway, it occured to me that it doesn't have to be an either/or decision. You can have tube connectors on the back of the speaker attached to the crossover net work by a pair of wires,  and also have conventional connectors also mounted on the back of the cabinet and attached to the same points of the crossover network with a different pair of wires. You might have to put a little sign on the back saying "use only one pair of connectors at a time".
You could also have a sliding cover over the connectors. Slide the door to the right and the tube connectors are uncovered, but the conventional connectors are covered. Slide the cover to the left and the tube connectors are covered, but the conventional connectors are uncovered.
I ran this by Danny and the Skiing ninja, and they both said it would work.
Danny Richie
« Reply #233 on: 1 Oct 2012, 01:13 am »
They do. The tube connectors accept standard banana plugs.
And I don't see it as de-valuing a cable by upgrading the ends. Another 20 minutes later and a new set of spades can be put on if that is what someone wants. No big deal.
jtwrace
« Reply #234 on: 1 Oct 2012, 01:16 am »
That's not true if you have any cable that has printed shrink tube on them from the factory.  Any decent cable guy does this so they know they haven't be touched.
There's a bit more to it then hack-n-cut.
Danny Richie
« Reply #235 on: 1 Oct 2012, 01:25 am »
Jason, there is nothing to terminating a cable. Cut, strip, crimp, solder, heat shrink....  And you're done.
jtwrace
« Reply #236 on: 1 Oct 2012, 01:29 am »
Really?  I had no idea.  Sorry, you just don't get it I guess.
Danny Richie
« Reply #237 on: 1 Oct 2012, 01:39 am »
Oh yeah, fancy labeled heat shrink. It would be a shame to loose that. That might de-value the cable hundreds of dollars.  :roll:
Funny thing is that I sell quite a few of those tube connectors to my customers. And I have had a few note a considerable improvement in the sound when swapping them into their speakers from various top level binding posts. They then order more tube connectors for all of their other speakers and extra male studs to put on all of their other extra speaker cables.
I think I get it, and my customers seem to get it as well.
Jonathon Janusz
« Reply #238 on: 1 Oct 2012, 02:46 am »
 :o
 :slap:
I am VERY sorry!  It seems like every time I try to type something into this thread, it just ends up going bad.  I'm going to do what I probably should have done from the start - I'm going to as graciously as I can bow out of this thread and hopefully let it get back to positive energy looking forward to hearing the new Super-7.
See y'all in Denver.
SoCalWJS
« Reply #239 on: 1 Oct 2012, 03:01 am »
:nono:
Danny
Never forget the puurty factor  :green:
There is something to be said for it - especially for those that have resale value in mind (at least in the back of their minds) when they purchase something.  :peek:
 :green: :green:
