Can you search member systems?
BeeBop
« on: 7 Jun 2004, 02:26 pm »
Is it possible to search member systems? I am researching pre-amps with an eye towards buying one over the next 6 months or so, and would like to be able to find what pre-amps are being used with the amp that I have (Bryston 3BSST).
Much obliged.
mgalusha
« Reply #1 on: 7 Jun 2004, 03:56 pm »
Not at the moment. I didn't build in a search function at the time. It didn't even cross my mind but of course in retrospect it seems an obvious fit. :)
If I can scare up some free time I'll look at modifying the member systems code.
BeeBop
« Reply #2 on: 8 Jun 2004, 09:25 am »
Thank you!  :notworthy:
