Poll
What is the most significant thing you can do to get great bass? Poll
Room Treatments
19 (22.9%)
System Equalization
8 (9.6%)
Multiple Subwoofers (2 or more) in Stereo
11 (13.3%)
Multiple Subwoofers (2 or more) in Monaural
6 (7.2%)
Depends on the System and Room
22 (26.5%)
Open Baffle Bass
6 (7.2%)
None of the Above
11 (13.3%)
Total Members Voted: 83
0 Members and 1 Guest are viewing this topic. Read 18577 times.
tim92gts
That's  alright, it might not be perfect but it should be good enough for experimental purposes. The glass wall gives you a higher loss factor at long wavelengths but you ought to be able to at least give it a try and see what happens.
Scotty
Glass walls must be the next  best thing to a tent.
We got the room ratios about right and the straight parallel walls  and floor all have glass opposite.
In addition the conservatory roof is multiple pitched.
Soaks up the power but it doesn't have strong resonance in bass.
