0 Members and 1 Guest are viewing this topic. Read 10227 times.
Hi.So it is "free" upgrade, not 100% free as you already paid for the old cables.FYI, Monsitor Cables, USA has offered free LIFETIME upgrade programme for many years now. c-J
They didn't have to offer it to past sales. They easily could've just changed it. So yes, it's free.
The vendor'd go bankcrupt in no time if it was really unconditionally free! Too good to be true!c-J
Hi.Really? So it is a real 'free lunch' though not what I read from the first post.The vendor'd go bankcrupt in no time if it was really unconditionally free! Too good to be true!c-J
I don't think anyone is questioning whether the change is worth it or not. It's free and a simple fix, but I don't get the "not wasting my precious time doing comparisons" logic. If that's the case, just ask Bruno which speakers, source and preamp you should own and be done with it. Isn't half the fun of this hobby the discovery of what sounds best to you? Cheers,Jack
no cables yet! hopefully i will see them soon. I just had my amps built by a friend, hopefully they come soon.
Okay. I finally had time today to install the "new" cable on one monoblock. My system still sounds great--like before. I may do the other side and also use a rhodium xlr connector I have on hand.
If you just purchased the modules you probably will NOT be getting cables as they were included. The new cables were for older kits. The easiest way to tell is ask your friend if the input cabling had a blue wire within it.
