V1 - build (photos on page 7)
0 Members and 1 Guest are viewing this topic. Read 34216 times.
SteveRB
Re: V1 - build
« Reply #120 on: 23 Nov 2012, 10:12 pm »
well,
the amps might have had the hum from the beginning. Once I got them hooked up, I started playing records immediately.
They have been plugged in for about a week. I noticed the hum a few days ago -- in the morning when the house was quiet. I can hear it walking through the room now.
How do I go about 'floating the ground"?
Early B.
Re: V1 - build
« Reply #121 on: 23 Nov 2012, 10:22 pm »
Put a cheater plug (3-prong to 2-prong adapter) on one of them.
SoCalWJS
Re: V1 - build
« Reply #122 on: 23 Nov 2012, 10:27 pm »
Float the ground -install "Cheater plug(s)" - three prong to two prong converter. If the hum has been there since the begining, and it's an older house, there's probably a ground loop issue.
SteveRB
Re: V1 - build
« Reply #123 on: 23 Nov 2012, 10:29 pm »
thanks,
I'm working on these issues in the power conditioning thread...
...hard to get a day off to really get into it though.
thanks again,
SteveRB
Re: V1 - build
« Reply #124 on: 2 Dec 2012, 08:50 pm »
Grounds lifted. Still humming.
The hum is coming directly from the amp, with my ear close to the heat sink.
nrenter
Re: V1 - build
« Reply #125 on: 2 Dec 2012, 09:34 pm »
Most likely, you have too much DC on your AC line (DC voltage on the line can cause transformer mechanical noise). You can DIY a solution, but I personally recommend an off-the-shelf solution (as AC can kill).
SoCalWJS
Re: V1 - build
« Reply #126 on: 2 Dec 2012, 10:06 pm »
Is the humming still as loud as it was before? If it's the same, you might as well get rid of the "cheater-plugs". You'll have to approach it differently as nrenter stated. This is one of the big problems with older houses that have mediocre AC running through them.
SteveRB
Re: V1 - build
« Reply #127 on: 2 Dec 2012, 10:39 pm »
Hum is the same with and without cheater plugs; I have removed them. I metered voltage: consistent 119-120v.
If I had to guess, it is transformer noise, like cheap track lights.
Can you suggest an off the shelf solution? Power issues and set up is a little foreign to me.
persisting1
Re: V1 - build
« Reply #128 on: 2 Dec 2012, 10:54 pm »
Can you post pictures of the finished speakers? Hopefully you'll get that hum issue fixed soon.
SteveRB
Re: V1 - build
« Reply #129 on: 2 Dec 2012, 10:58 pm »
Pictures to come.
I was called out of town to help with a family health emergency for the past couple weeks. I'm sure I will bury myself in finishing them next week.
They are currently 'taped' together but playing music fantastically.
stevenkelby
  • Adelaide, South Australia
Re: V1 - build
« Reply #130 on: 3 Dec 2012, 12:46 am »
If I were you I would contact Dave from PI Audio, he knows about such things and can probably sell you something to fix your problem:
http://www.audiocircle.com/index.php?action=profile;u=41236
Best,
Steve.
SteveRB
Re: V1 - build
« Reply #131 on: 6 Jan 2013, 12:11 am »
V!
Early B.
Re: V1 - build
« Reply #132 on: 6 Jan 2013, 12:41 am »
Awesome!
persisting1
Re: V1 - build
« Reply #133 on: 6 Jan 2013, 01:54 am »
Simple and clean. Easily my favorite build to date. Congrats.
PDR
  • May the best man win
Re: V1 - build
« Reply #134 on: 6 Jan 2013, 03:07 am »
Very nice Steve.....looks fantastic!
bdp24
Re: V1 - build
« Reply #135 on: 6 Jan 2013, 03:46 am »
+1. Less is more! Understated, clean, and classy.
corndog71
  • Some people call me Rob.
Re: V1 - build
« Reply #136 on: 6 Jan 2013, 03:53 am »
Love it.  Well done! :notworthy: :notworthy: :notworthy:
Guy 13
Re: V1 - build
« Reply #137 on: 6 Jan 2013, 04:58 am »
Hi Steve and all Audio Circle members.
I should have (Originally) built mine like yours.
Be proud, nice work.
Guy 13
Re: V1 - build
« Reply #138 on: 6 Jan 2013, 05:36 am »
Agree with all the above,  they look great.  Necely  done !!
-jay
SteveRB
Re: V1 - build
« Reply #139 on: 6 Jan 2013, 05:05 pm »
Thanks for the help along the way everyone.
Simple and clean...
My first priority was to make it look like a speaker -- that's it. That's also the reason I went with the black grill cloth. The lighter colours made the whole the thing look a little precious. Right now they are pretty unassuming; until I turn them on, then the eyes widen and the jaws drop.
