Salmon. Smoked.
Bob in St. Louis
Salmon. Smoked.
« on: 26 Aug 2012, 02:58 pm »
3 pound fillet, $21
2 handfuls of jalapenos $1
1/2 cup Kosher Salt
1 cup brown sugar
1 tsp thyme
1 tsp rosemary
Lay a sheet of aluminum foil, several inches longer than the fillet
Lay a sheet of plastic wrap on top of that.
Lay the well mixed dry ingredients in a bed on the plastic and lay the fish (meat side down) on top:
Sprinkle a liberal coating of kosher salt on the skin side:
Wrap plastic first, as tightly as you can.
Wrap aluminum as tightly as you can.
Put on a cookie sheet and place in the fridge with weight on top. I used a couple gallons of milk)
Let sit for 12 hours. Flip fish and weight down for another 12 hours.
Then rinse off the dry ingredients and let air dry for a few hours.
Not much fuel. About 20 briquettes. In the chimney is another 10 or so briquettes that are lit and poured on top of the main pile.
(This is called "the minion method") The thought process is that the hot stuff you pour on top takes a very long time to burn down.
A handful of scrap cherry wood left over from a woodworking project gives some flavor:
About 26-28 hours after wrapping and drying:
At this point I was worried I had made salmon flavored leather, but I continued on like I knew what I was doing:
Oh.....I forgot the appetizers.
De-head, de-seed, and de-vein some Jalapenos using the handle of a spoon and stick in little chunks of swiss cheese.
Since that wasn't enough, I wrapped them in bacon.
Figuring if I lay them down, the cheese would run out, I tightly covered a deep pan with aluminum foil and poked holes in the top that the peppers would "nest" in.
(I was pretty proud of that one).
Some homemade shells and cheese.
I also made Jasmine rise using chicken stock instead of water.
David C
  • Don't try and lay no boogie woogie on the king
Re: Salmon. Smoked.
« Reply #1 on: 26 Aug 2012, 04:18 pm »
Bob
lookin good. How long did you leave it on the smoker, temp? and did you use a water pan? Did you cook it skin side down with no foil wrapping. Looks yummy
David
Bob in St. Louis
Re: Salmon. Smoked.
« Reply #2 on: 26 Aug 2012, 04:27 pm »
All great questions David.
THe smoker temp was about 225. I've got a wireless temp probe that I kept an eye on the internal temp of the meat.
My goal was to take it off at 140`, but I got sidetracked and took it off at an internal temp of 152. No regrets though, I can't imagine it tasting any better had I removed it 12` earlier.
I couldn't even begin to tell you how long it was on. If I gave a number, I'd be lying. The importance was the internal temp reaching 140.
Skin side down, bare nekkid. No foil, not even any additional spices.
Well, I did give it a bit of olive oil rubdown, but that's it.
Before serving, I cut the portions to size. Then I ran the knife between the meat and skin (like scooping up a slice of birthday cake) and the skin seperated like it wasn't even there.
The worst part of the entire deal, was finding and removing the 'pin bones'.
I Googled a couple videos of it, and it turned out to not be as easy as it looks. A (very clean) pair of needle nose pliers helped out a lot.
Turns out there is more than one row of pin bones. None of the videos I saw told me that.
Bob
David C
Re: Salmon. Smoked.
« Reply #3 on: 26 Aug 2012, 05:02 pm »
Bob
thanks.I am going to give this  one a try over the Labor Day weekend
I enjoy your smoker threads so keep them coming
David
Bob in St. Louis
Re: Salmon. Smoked.
« Reply #4 on: 26 Aug 2012, 05:11 pm »
 :lol: Thanks David. I have no doubt Rob and I will be able to keep you drooling with pictures.  :wink:
bearman2
Re: Salmon. Smoked.
« Reply #5 on: 26 Aug 2012, 05:17 pm »
Salmon is one of my favorites to smoke. I usually use apple or hickory but I will try cherry because that sounds good. Your fish looks wonderful..
totoro
Re: Salmon. Smoked.
« Reply #6 on: 26 Aug 2012, 06:45 pm »
I worked in restaurants when I was young, and we always used heavy tweezers for the pin bones. Something like this:
http://www.cutleryandmore.com/global/fish-bone-tweezers-p11317?gclid=CNiA2bn5hbICFUJo4AodD3MA0A
Most big Japanese grocery stores will have something similar for more like $15.
Rob Babcock
Re: Salmon. Smoked.
« Reply #7 on: 26 Aug 2012, 07:28 pm »
The stuff we get now (at work) has very few if any pin bones.  But "back in the day" it all came that way.  I used a needle nose pliers.  It wasn't difficult but then I did a couple hundred pounds of it every week, so you get pretty efficient at it.
Very nice looking salmon!  Since my smoker showed up on Friday work has kept me from having the chance to condition it but soon... :thumb:
ptmconsulting
Re: Salmon. Smoked.
« Reply #8 on: 30 Aug 2012, 03:29 pm »
We smoke salmon all the time. I get fresh Atlantic salmon right off the boat - BIG difference over the store bought farmed fish.
I smoke at about 225 for about 1.25 hrs. It's my family's favorite. When I serve this to people who don't like fish they immediately make this the exception to their rule.
persisting1
Re: Salmon. Smoked.
« Reply #9 on: 30 Aug 2012, 08:51 pm »
People don't like fish?  :scratch:
