Tempestas and N-core amps
0 Members and 1 Guest are viewing this topic. Read 10098 times.
bigbang
Re: Tempestas and N-core amps
« Reply #20 on: 31 Aug 2012, 12:10 am »
I think those (floorstanders) should make a stop in Southern MI for a break in session before being delivered to maxboy00. I'm just trying to help! :lol:
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #21 on: 31 Aug 2012, 12:11 am »
$4,795 to $4,995/pr. including shipping.
Sparks
« Reply #22 on: 4 Sep 2012, 01:16 am »
So how does one go about building an amp centered around the Hypex Ncore amp?
jonbee
« Reply #23 on: 4 Sep 2012, 02:21 am »
Go to the hypex owner's circle here. Everything you need is there.
Sparks
« Reply #24 on: 5 Sep 2012, 01:15 am »
Thanks, jonbee.
Did you DIY them?
jonbee
« Reply #25 on: 5 Sep 2012, 02:22 am »
Thanks, jonbee.
Did you DIY them?
I'm in process of building them. I bought the chassis from member HT cOz (very nice, and fully precut and drilled for the project). I've gotten all the parts except the amps, on backorder with Hypex.
The project is fairly simple and straightforward as DIY goes. The Hypex modules are really well set up to make it simple. I expect a completion time of around 4-6 hours.
If you have no DIY experience it will be more of a challenge, but not impossibly difficult even then. Then I would certainly recommend the HT cOz boxes, as they are nicely setup for easy construction with no metal work required at all.
Rick Craig
  • Selah Audio
« Reply #26 on: 5 Sep 2012, 02:37 pm »
If it was on my way... :(
maxboy00
« Reply #27 on: 5 Sep 2012, 06:43 pm »
Sorry to disappoint, there will be no detours!
bigbang
« Reply #28 on: 6 Sep 2012, 12:19 am »
Well ok then :cry:! But photos and a full review will be in order ASAP!
