0 Members and 1 Guest are viewing this topic. Read 22870 times.
Where are you going Wayne?
I am getting closer to a decision. I was able to speak with support at Sonos and also with Steve at Empirical. Both were very helpful. I was not able to connect with Audio Engine. I am leaning toward getting a Sonos Connect ($349) and Bridge ($49), the Empirical Audio SynchroMesh ($599)and either an iDac($999) or a Metrum Octave ($995). That gives me a connection I can trust and great sound. It was Steve who suggested both the iDac and Metrum Octave and I've read very good things about both. Going with the Sonos is cheaper than the Audio Engine and I am not too keen on connections on the front panels on the AE. BTW, the help at Sonos was great...very nice and knowledgeable. Of course, this puts me over budget and my wife went off a bit with my mention of upgrading. I'll have to buy the components over time and may need to look at less expensive dacs as well. Thanks for all the comments
Start with just the Connect and Bridge. If you're not satisfied with the sound, add a DAC. There are a lot of well regarded, much less expensive DACs on the market these days. The Schiit Bifrost for $350 has been getting a lot great reviews. Add the reclocker last, and only if you really think it will add something.It's a shame the Sonos system doesn't offer USB digital out or hi resolution audio playback, but the system does seem well designed for easy setup.
Underwood wally offers Sonus mods that will reach 192, but it'll shoot your budget.
I agree with you on this so I have decided to first go with the Sonos Connect and Bridge.....I just want to be able to play music again. Down the road, I will get a dac and also consider the SynchroMesh from Empirical or the Sonos mod from Wyred4Sound. These mods appear to be quite similar.
Is there a way to connect a USB HDD (with about 300 GB of .flac files) directly to the Sonos, and play the files without the need for a separate computer or NAS?
Hey nick, perhaps this is coming too late, but you may want to take a look at Olive products. www.olive.us. They have a wifi player at retail $600 and server at $999. All w/ wifi & ipad / phone / touch apps. Have not actually used one myself, but they do look sweet and have mostly the right specs for a somewhat reasonable price. I got a duet recently & haven't experienced that many issues - but perhaps cause I'm running it w/ ethernet & not wifi. I'm not getting the drop out as I did with the airport express, and I like the controller (which can be a streamer on it's on). Eventually looking to probably do a modded mac min w/ iphone remote software, but that's another story.
Olive is on the right track, but files are saved iwith proprietary earmarking. There's whisperings around suggesting that they may give that up.Here's a product that looks very good, just not available yet in the U.S. (projected for summer/fall of 2013). They even offer a model with built in 50 wpc amps:simpleaudio.co.uk/
You are correct Nick - Olive 3HD is ethernet only....was aware that it didn't have digital out, but not about the non-wifi. But if you're gonna store your files elsewhere, the streamer only O2M does do wifi & costs $600. Still more than the Sonos Connect / Bridge combo at $400 retail though. So I think you're conclusion probably makes the most sense (unless maybe you can find the Olive stuff used at a steep discount).Seems to me that the price gap between )3HD & the more desirable 4HD is way too wide to justify : i.e. $1K vs $2.5K : between the wifi, bigger hard drive, digital outs, and better internal dac chip for the 4HD does not equate to $1.5K difference - more than double! Pricing seems more reflected towards a marketing & revenue objective than actual costs. And as these are more likely geared towards an audiophile market, the "entry level" one seems almost purposefully de-contented towards that objective. Welcome again to "high end" audio........
