0 Members and 1 Guest are viewing this topic. Read 14738 times.
Several places, including on here. I think it has to do with dispersion if anything and apllies to a 8" fullrange driver as well.
If we have speed of sound = 1135ft/sec, then an 1135Hz tone is 12" long.If I have an 18" baffle, then the 6db per octave roll-off will begin at 12"/18" * 1135Hz * 2 = ~1500Hz.
How many octaves can I stretch a driver across, seems like 2 at the most
How come most of the open baffle designs I see are 2-way. Seems like 3-way is the bare minimum.
The 3" was then down 6db at 200Hz.
But if I use a 8" full-range driver far above its upper beaming frequency and the baffle's dipole peak (and break the rule anyway) as well as DSP, all this does not really matter anyway and it would be better to try to get a bit more bass response out of the FR driver...?
I always try to keep the baffle shape and the driver position symmetric to the vertical axis - with the driver as near to the baffle top edge as possible. "Sculpting" the baffle to get extremely flat on-axis diagrams in Edge doesn't lead very far. In most cases the best on-axis-response compromises the off-axis response to one side.
The 2 or 2.2 times driver size rule is a guide which places the dipole peak high enough in frequency so that driver directionality takes over and prevents the appearance of the first null and maintains a quasi-dipole response due to driver directionality in the front hemisphere. But the bottom line is that you really need to build and measure the polar response to see what you have.
OK so you recommend I keep the 8" FR driver centered on my 18-24" baffle (horizontally) for a symmetric off-axis response (+30° response equals -30° response) although this would compromise the on-axis response itself?
And this is despite the fact that I will be (i) listening strictly on-axis, ... Wow, the off-axis response must be more important than I could have imagined - and I don't mean that in an ironic way!
I cannot place the FR driver close to the upper edge since I would like to leave real estate for a potential super tweeter - unless I put tweeter below the midrange, i.e. between it and the woofer.
