Also the problem with the other plugs is that they have to be bought in huge quantities, so the $2.50 each thing is really $250 for 100 pieces.
The only issue with these is they can break if treated rough. Actually, the plug that broke was purchased through Audio Magus.
Next to zeke, I got the tubing at Ace hardware, but I'm sure you can also get K & S at Menards as well as many other hardware stores.
I purchased a bunch of the Swiss made spring steel type BFA's from Take Five Audio. I have been using these for a couple years now and they fit nicely in any post I have used them. You would have to abuse the crap out of them to break them. Very good contact but you cannot crimp these. On speaker cables I just care about an easy good connection. They work very well.
