Audio/Video Gear and Systems
Headphone Mania
Letitroll98
Help replacing headphone cable or selecting extension cable
Al Garay
ยป
1 Jun 2004, 05:50 am »
Hi,
Any recommendations on extension cable? or a way to replace headphone cable?
Looking to replace the cable for a Radio Shack Titanium headphones that my daughter's use in the car for road trips. The cord has gotten frayed in several places to the point were it no longer works.
These are the headphones, made by Koss:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F007%5F003%5F004%5F000&product%5Fid=33%2D1182
I don't see an easy way to open the ears to get to the wire connection. So, I'm thinking of replacing from the Y adapter down to the plug.
I would love to get an extension cable similar to the Grado's though not for $40.
Thanks for the advice,
Al
bhd812
3 Sep 2004, 07:11 am »
well maybe since its koss made any thought of using their lifetime warranty?..maybe worth a try
ext cable can be made using cat5 cable..you have any of that lying around?
Headphone Mania
Letitroll98
