0 Members and 1 Guest are viewing this topic. Read 17463 times.
Gee Thanks DS! And why do I value you opinion?
Finally, for the OP. I've been meaning to try the White Lightning Moonshine speaker cable. Similar, but not the same, to Barry's home brew, only using Wal Mart extension cord. http://www.6moons.com/audioreviews/whitelightning/moonshine.html
I like DS-21's idea of Mil spec cables too, there is tons of surplus cable of extraordinary quality available for the DIY person, and DIY cable building is fine for even the rank amateur. Unlike DS-21, I think you can get significant differences in speaker cables by altering geometry and material, in that order. There are sound engineering reasons for this that are well documented and easily researched on the web.
I would not recommend either silver plated nor tinned copper wires, go with pure OFC copper, or pure silver, or an alloy.
Which is kinda silly on the C&C circle. I mean, it's not like anyone's gonna splurge on mega buck cables in an under $1000 system.
Reasonable people of moderate or better intelligence do not give credence to phenomena that do not exist, such as the "sound" of audio wiring. They don't tend to believe in Bigfoot or the Loch Ness Monster, either.
Glad that the OP was able to get some free wire, though. Hopefully it's not the stuff that turns green.
Quote from: Barry_NJ on 20 Jul 2012, 08:48 pmGee Thanks DS! And why do I value you opinion?Oh, so now fluffy audio postmodernists don't value anecdote? snip...
For myself, I hold these truths to be self evident:1. Cables can affect the sound, particularly due to varying differences in resistance, capacitance and inductance and can sometimes be responsible for good or bad "synergy" between components.2. I won't spend big bucks for a cable ($50 - $100 max)3. I won't buy a cable, even if within budget, if it has the word Liquid, Ceramic or Nano in the name. Or Monster, but that's a given.Steve
Second, might I gently suggest it's not the best idea to pick a fight with the guy who can delete your posts and ban you from the circle. Not making any threats here, just a gentle suggestion that you may do with as you please.Happy posting and have a great day.
Wouldn't be his first ban from a forum...
What happened to cheap and cheerful?
Finally, for the OP. I've been meaning to try the White Lightning Moonshine speaker cable. Similar, but not the same, to Barry's home brew, only using Wal Mart extension cord. http://www.6moons.com/audioreviews/whitelightning/moonshine.html Note this is not the Nordost product of a similar name, although their White Lightning speaker cable is moderately priced for a retail cable, nothing like a Cheap and Cheerful product.
I am hoping to install some old Western Electric cotton insulated wire. Have I been rambling again? ﴾͡๏̯͡๏﴿
