Try an EQ, you just might like it (long)
0 Members and 1 Guest are viewing this topic. Read 9034 times.
zybar
« Reply #40 on: 3 Jun 2004, 04:54 pm »
Never used that software.
George
mb
« Reply #41 on: 4 Jun 2004, 01:12 am »
Quote from: heavystarch
MB:
How do you make this adaptor cable for the AES/EBU to S/PDIF?  If you friend has any instructions or guidelines on how to do it I sure would appreciate it.
As I indicated, it's in the Behringer manual. Don't know if they're online as PDFs... I also recall an article or two on the www with instructions. Sorry I don't a have a schematic or diagram online.
