0 Members and 2 Guests are viewing this topic. Read 243879 times.
Mike,Thanks for answering my question. I see you have put a lot of thought into using LiPo packs and sharing your experience is most appreciated. There are many on this thread who may take you up on your suggestions.Would this battery unit be OK or is the amp level, 3a @ 19v, to low?http://www.amazon.com/Anker-Ultra-High-Multi-Voltage-Notebooks-Compatible/dp/B00B45EOYS/ref=pd_sim_e_1or this one?http://www.amazon.com/Capacity-33600mAh-Portable-External-Notebooks/dp/B0063KXZQ2/ref=pd_sim_sbs_pc_3Chris
We're out of sync, Chris - leap frogging each other.
I recall reading earlier in this thread about using one channel on each of two amps and that Jan had predicted a 30% increase in Wpc, but I'm clueless as to why the unused channels have to be shorted. ?
Very nice...been following the thread over on Head-fi.
Very nice...been following the thread over on Head-fi. How many cards can the M10 handle at the same time?
Jan heard the modded Cardas post version of Rex and mine and now is offering this on his website for $650. Jan was impressed.
+1 Good thinking. That is excellent use of the amp. I bet it sounds great!
I talked to my friend in Michigan recently, that is using two Millenia amps as dual monos. He recently purchased a pair of the 8K plasma tweeters from Vaughn Acoustics to run with his Vaughn Line Arrays. Kenny told me that if he had only 10K to spend on an amp, he would have to buy two of the Millenia amps and these plasma tweeters. Kenny says those tweeters are a game changer for him. That is high praise to be running TBI's on that 40K system.Audio Beat rated the Vaughn/Wavelength system as the best at RMAF.
Sorry to resurrect such an old thread, but I was just checking to see if you guys are still happy with your TBI Millenia amps. I just purchased mine and it should be here in a few days. I plan to use it on some single driver fullrange speakers I've got. These particular drivers used (Mark Audio Alpair 10.3) are incredibly revealing of upstream changes and tweaks so I'm curious to see how the test goes.I'll also be pitching the TBI against my reference tube preamp and Class D Audio SDS-120 which are currently holding down the main rig duties. Should be interesting to see if the TBI can dethrone my current gear. Will report back with findings when the TBI arrives.Cheers,StevenZ
