Comments from my short time spent with TBI. My speakers are Zu Definition MK4's, 101db sensitivity with on board powered sub. Amp is a Melody I2A3. The first night I listened on ac power, the sound was decent but not very engaging, thin sounding. The second night although I knew I was not going to be able to sit and listen I hooked up the batteries and turned it on. Working in the adjacent room it kept grabbing my attention. I had to keep running in to sit and listen for a few minutes. I could tell right away it was a much different amp on battery power. Unfortunately the batteries did not last very long. I charged them overnight with the thought of spending most of the weekend doing some serious listening. I began listening again on Sat. playing select cuts from different discs. I was really surprised on how much better the bass was on battery power and as Tom has been saying sound staging and imaging is just crazy good. I was listening fairly loud most of the time and the amp seemed to be coasting along unfortunately the batteries died again after about 2 hours. The Melody being a quality amp although not up to the level of the Zu's does an admiral job with them. As short as my time was with the TBI I'd say it trumps the Melody in every aspect. I must say the Melody is the only amp I have heard with Def 4's so I have no other comparison's. It would be nice to try it with a pre amp to gain at least another input. No doubt it will get better with the coming tweaks.
Something to note, I have my Virtue on a set of batteries permanently connected to a high quality charger... There is no fear of running out and my amp is always warmed up. - kinda the whole point. The idea of batteries is not to be panicky and looking over your shoulder with a multimeter, it's to have them always on charge.
Okay so my amp arrived here in the UK today. It does sound totally different on the internal batteries. I'm curious to know though, did you guys compare internal to your battery pack? And why would the battery pack sound different? I've not had any issues with how loud it goes.I am a bit concerned about this talk about the batteries draining.. I was going to buy one of these:-http://www.razorbase.co.uk/Razor_Spare_Parts/Razor_MX350_Dirt_Bike_Spare_Parts/Razor_RAZ143_Batterybut should I just buy a AA battery pack?http://uk.rs-online.com/web/p/aa-rechargeable-battery-packs/5440239/
Greetings to everyone here...long time lurker and first post .Just wondering, has anyone tried using lifepo4 batteries?Reason I'm asking is because I would like to use a lifepo4 battery packbut the nominal voltage is 25.6v and a little higher hot off the charger.
Whatever. I'll be testing this thing 8om, 4ohm battery, no battery, we'll see.
Oh do you think these speakers would be a good match for the amp?http://www.superfi.co.uk/p-3408-epos-epic-5-floorstanding-speakers-pair.aspx
