0 Members and 1 Guest are viewing this topic. Read 13478 times.
2.5 L push/pull compound vented cab (that's 1/2 the size of a sealed box) = -3db at 27.5 Hz
It is an Isobaric.
You've got it in one. Locate it in the center of the rear wall and run it out of phase, ideally you would like to be closer to main speakers and front sub than you are to the rear sub. This gives you time to hear the bass wave. Before it is canceled out by the output from the rear sub. The crossover frequencies should be matched front to rear. If you have to sit closer to the rear sub than the front sub then you will need to add delay to the rear sub so that it cancels the front wave before it hits the rear wall but after you have had a time to hear it. The Behringer DCX 2496 will allow you to dial in the right amount delay.Scotty
