my knowledge of plate amps is nil. more research required. thanks.can you supply a finished wiring diagram, including the receiver, or point me in that direction? thanks again.
I use two of these Daytons amps which have built -in crossovers to drive my H-frame Alphas. They can be daisy chained ( mono or stereo ) and each has a volume control. I bought them when they were on sale for $120 each. They were formerly sold by Emotiva.http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-812&FTR=apa%20amplifier
Hmmmmm. having a few thoughts.......I own but no longer use a sony subwoofer. If I remove that dual voice coil speaker, can I wire the rest in to my existing 3-way setup? or is that loony? it has controls for cut-off freq, phase and level. thanks for any help, and sorry if thread appears hi-jacked.
I also like splitting the source. In my case I take the analogue out put from the CDP and send it to my integrated tube amp which drives the full range mains. Then I take the digital output from the same CDP and send it to a Denon AVR which drives the bass woofers through a 80hz low pass.
Matevana, do you have a complete build thread and x-over diag. for this. I think this might be my first OB project, I already have the tweeters and like everything else Ihave read in the thread it seems to be incredible bang for buck.
Just curious - why did you switch to passive? Why not just keep the active crossover in place?
I personally like the sound of OB bass (for music). The person in the other thread had an existing vented box he wanted to use in conjunction with an OB top. In his case, the Hestia minus the the LF driver would be fairly easy to integrate. Personally I wouldn't change anything about the design. It is very balanced at moderate SPL's and the bass is not lacking. I would use a decent plate amp as lesser amps might have trouble keeping up. With the x/o set at around 90 Hz, very little would be gained by using a 2nd plate amp and running the sides in stereo. Certainly something you could try later as an upgrade, but I believe you will be very happy with mono bass as intended. For amps I highly recommend either the Yung 300W with boost @ 30Hz, the O-Audio Bash 300 or the Dayton Bash 300, in that order. Other amps that I had on hand did not sound nearly as good. When they go on sale, you can get any of the three for right around $100. I have the Yung driving my Hestia right now, and it runs cool even after many hours of use. For the top I alternate between a NAD integrated amp and a Topping Tripath chip amp, and still cant decide which one I prefer. Both sound excellent with the design.
Matavena, again thanks for the response/opinion. I also want to keep it OBbass, but I would like to use the Dayton PA310 for the bass duties and either go withthe Yung 500W mono or 2 300w stereo on the bottom. Is there any issues with the X-over point going mono with 2 8ohms vs. stereo with individual 8ohm drivers. I justwant to kick it up a notch and still think it would be a budget build. Let me know youropinion. I'll call it "Hestia Grand" LOL Thanks SQUIDSPEAK
