Well got everything assembled and wired; and wow. Trying to get them broken in forthe NY/NJ DIY event on SAT. So far incredible bass from the 15" woofer and crystalclear mids/treb. I will let you know how they do at the big show. And pics of course.
Hi MatevanaI have 4 of these 12"http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-55-2962-/55-2962Can use it as mid? The big difference is sensitivity.What you think.Thanks.
Will you/they be in the shop tomorrow?
Ed, thanks for the heads up on this. I considered the Hawthorne 15" Duets much for this reason, but I'd like a smaller footprint (and price tag) than they have, hence looking at DIY 10's. Your design hit me just right; it wasn't too large, too costly and everyone had done so much development it seemed like a no brainer. I don't have a workshop anymore (traded a back yard shop for a river ) so a lot of trial and error is just not viable. I guess I'll keep looking. If any of you guys have seen a design using 10's like this one that may meet my goals of a solid punch, clean sound all round and OB, please point me in the right direction. I'd be most grateful. No matter what, thanks for taking the time to help me out!
Squid OB at Casa De Rodge
You might want to check with Squid since he uses a larger bass driver with a similar footprint. It isn't that they don't go low enough or get loud enough... they do. It's the way they interact with the room that's different. Picture your drum set in a recording studio with foam on the walls and ceiling. Your kit would sound very articulate and uncolored... not what you would expect in a club or live setting.
