two rca's out of preamp
0 Members and 1 Guest are viewing this topic. Read 1357 times.
guf
« on: 5 Jul 2012, 05:58 pm »
  the transcendence 8+ has two. whats the reason for this?
« Last Edit: 5 Jul 2012, 07:11 pm by guf »
PSB Guy
Re: two rca's out of preamp
« Reply #1 on: 5 Jul 2012, 07:22 pm »
If I'm not mistaken, all the AVA preamps are equipped with two line outs. One reason I can think of is to make hooking up a subwoofer (or subwoofers) easier.
Cornelis
avahifi
    • http://www.avahifi.com
« Reply #2 on: 5 Jul 2012, 09:25 pm »
Correct, we supply two sets of audio output jacks because many users like this as it makes connection to a separate subwoofer amplifier easy.
You could also drive a second power amp to run speakers in some remote location.
Note that both sets of audio outputs provide identical signals, driven by the normal audio output circuits.
If the preamplifier has our phase inverter bridge circuits option, then the Line Out 2 jacks will provide audio signals 180 degrees out of phase with the Line Out 1 jacks.  This is used to allow bridged mode operation of many stereo amplifiers.
Frank Van Alstine
