0 Members and 1 Guest are viewing this topic. Read 31854 times.
remember the Oppo will not play gapless through the USB input.
The Oppo will support drives up to 2TB, they need to be formatted in FAT32 or NTFS. You can hook it up directly using USB or eSATA, or stream from a PC/Mac using a DLNA server. It won't play Apple Lossless, it will play just about any other codec. For Mac, Playback is a good, inexpensive DLNA server if you want to go that route. If hooked up directly, it shows up under Music on the home page. Streaming is under network. You can use "GOTO" to navigate a little easier. If connected directly, you can set up a play list. The green button will put tracks in the playlist. There's a huge thread on AVS with tons of information and the regulars there are very helpful.
"gapless" huh?? (remember - computer novice)
I sprung for the BDP-95. Love it as a disc player but, I've got all these digital files. Unfortunately most in Apple lossless. Guess I'm back to looking for a Mac-Mini. Thanks for all the responses
