Jolida 1501 amp - opinions/experiences appreciated
0 Members and 1 Guest are viewing this topic. Read 2289 times.
funkytabla
« on: 29 May 2004, 11:36 am »
Hi All
I've got interested in the jolida 1501 hybrid amp
But being based in the uk, these are impossible to demo, and nor that easy to get hold of.
I would really like to hear any views/experiences of this amp. I'm after a smooth, slightly laid back sound.
thanks
funkytabla
ps. The amp would be matched with a pioneer 747a dvd transport/CAL sigma II dac and dynaudio contour 1.3mk2 speakers. (The speakers are 4ohm/86db, supposed to be difficult to drive, but have a linear impedence and basically need a steady current output. Also, I rarely play music really loud)
Hantra
« Reply #1 on: 29 May 2004, 06:25 pm »
Funk:
I used to own this one.  I enjoyed it thoroughly.  I think it has the sound you are looking for.  Not too smooth, and just laid back enough.  I can't say whether it will drive your speakers or not, but it does have a really beefy transformer.  I got rid of mine and moved into a Roksan Caspian.  I don't know why really.  At that point, I was blowing through gear weekly, so I don't remember if I liked the Roksan better, or not.
I can say that the guys at Jolida are great, and their service is really good.  I screwed mine up trying to mod it.  But I never expect anything to actually power on again when I try to mod it.   :lol:
funkytabla
« Reply #2 on: 29 May 2004, 07:08 pm »
Hey Hantra,
Would u believe I have a roksan caspian at the moment!
I'm venturing into tubes, but not too much, so hence the query about the hybrid Jolida.
Do u recall, how the two amps differed?
I suspect that this jolida may be a bit of a sideways move when compared with the caspian? But I'm finding it a bit too edgy with the dyn contours, which are rather too revealing sometimes.
funkytabla
Hantra
« Reply #3 on: 29 May 2004, 08:10 pm »
Quite honestly, I think the two amps are similar, but the Roksan seemed to have more oomph.  I do think the Jolida has the potential to be smoother, but I never rolled any tubes through it to find out.  I should have done that, but like I said, I was blowing through gear like there was no tomorrow at that point.
To be honest with you, I didn't find total satisfaction until I met the Plinius integrated I had.  If you want smooth, and powerful, that's the way to go.  They are more money than you are talking here, but I do think the Roksan -> Jolida move would be quite lateral.
What's your digital front-end?  Perhaps that's the culprit?
B
funkytabla
« Reply #4 on: 29 May 2004, 10:21 pm »
Hi Hantra
My source is a pioneer 747A dvd transport & cal sigma II tube dac, so I doubt very much the edginess is down to this. A few users have said that the caspian can be a little harsh, though the overall opinion is to the contrary... :?
I think it's basically because the dyn speakers are just too revealing, and play what ever they find. On good recordings/most jazz & acoustics fine, but on a some dance stuff, the compressed/eq'd recordings sound a bit harsh & over-sibilant. I've tried these types of cds on other systems with similar types of results, though perhaps not as bad.
I suppose I could get some smoother speakers, but the contours are superb, so would like to keep hold of these. What I'm trying to do is tune the system further to be a bit more relaxed, hence possibly going down the hybrid tube amp path.
Apart from the whole modding path thing which I'm inept, another possibility would be getting a tube preamp, but adding another box.
In terms of ss, one amp I'm demoing soon is the the audio analogue puccini se. The plinus is beyond my budget :(
I still would like explore the hybrid tupe amps, though there as so few makes available in the uk
funkytabla
Hantra
« Reply #5 on: 30 May 2004, 12:03 am »
Man I am in San Fran for a week and I went shopping today.  ;-)
I heard the latest from Audio Analogue.  Smaller amp called the Primo.  It's very smooth.  I think it retails for $800!  Pretty too . . .  My wife even liked it.
Let us know what you end up with!
B
funkytabla
« Reply #6 on: 30 May 2004, 04:57 pm »
Yeh, the primo is a new cheaper amp from AA. Haven't heard it yet, but also alongside the accompanying cdp, has had rave reviews in the uk mags, FWIW.
