Syrnergy 450 comparability with other preamp
0 Members and 1 Guest are viewing this topic. Read 1917 times.
ricardojoa
« on: 27 Jun 2012, 05:24 pm »
Hi,
what should i be looking when pairing the synergy450 with other branda preamp? Like any specs i need to look at to match the amps?
Thznks
avahifi
    • http://www.avahifi.com
Re: Syrnergy 450 comparability with other preamp
« Reply #1 on: 27 Jun 2012, 06:39 pm »
The Synergy amplfiiers have a voltage gain of 25.  This means 2.4V will drive the 450 to full power. 2V will drive the 300 to full power.  This is close to the industry standard.
The input impedance is 24.9K ohm and a pure resistive load.  This is a relatively easy load for any well designed preamp to drive.
The amplifiers are safe in four ohms and nearly double power into four ohms, up to the limits of the speaker fuses. If the fuses are too big, speakers could blow first.  the 450 is safe into 2 ohms, the 300 too if it has the double die option ($99).  Double die devices are standard on the 450.
The Synergy amplifiers are  very smooth performers, but give away nothing in detail, transparency, dynamics, and musicality.  We suggest that they sound like a great tube amp should sound, if the tube amp only did not have the handicap of output transformers and very limited current drive.
We think you will really enjoy a Synergy amplifier no matter what the rest of your system consists of.
Frank Van Alstine
ricardojoa
« Reply #2 on: 16 Jul 2012, 01:39 pm »
Just a couple more question since it is having the sale.
How much is the 240v international voltage? My country is 220v, wouls there be any problem power the amp?
What carrier is used to send the amp, any special rates?
Can the faceplate be replace withe the gold one like vet valve faceplate?
Thank you
avahifi
« Reply #3 on: 16 Jul 2012, 02:28 pm »
We can wire the Synergy 450 for 220/240V 50Hz for you at no extra charge right now.  It works fine on either voltage as it has all regulated power supplies with plenty of headroom.
We can install the silver (not gold) thick faceplate with electronic switching for $300 extra on any black faced large AVA power amp.
Of course right now you would save 15% on the total price as our sale is going on until September 30th.
In general we use either UPS or air parcel post for shipping depending upon the weight and value and if full insurance is available to your country.  We pack very carefully for safe shipment and almost never have shipping damage.
Frank Van Alstine
