MAC Music Player
  • The Demo is Everything!
    • http://www.bryston.com
MAC Music Player
« on: 23 Jun 2012, 02:17 pm »
Hi folks
Playing around with my MAC laptop and tried ITunes of course and Songbird as the music player. Are there any others that will do 192/24 other than Amara?
James
InfernoSTi
Re: MAC Music Player
« Reply #1 on: 23 Jun 2012, 02:42 pm »
I use Decibel on my Mac (when I'm not using my Squeezebox Server).  Plays 24/192 I find it sounds best with when it loads song into memory...a check box to select under "preferences" if I recall correctly.
http://sbooth.org/Decibel/
Best,
John
« Reply #2 on: 23 Jun 2012, 02:46 pm »
I use Decibel on my Mac (when I'm not using my Squeezebox Server).  Plays 24/192 I find it sounds best with "hog" mode...loads song into memory...under "preferences" if I recall correctly.
Best,
John
Thanks John.  I assume the 192 would be a function of the soundcard in the MAC being capable of 192?
james
groovybassist
« Reply #3 on: 23 Jun 2012, 02:47 pm »
I've been using Decibel and last night downloaded Audirvana to compare.
groovybassist
« Reply #4 on: 23 Jun 2012, 02:49 pm »
James:
24/192 via USB should be no problem on a Mac. I believe the optical out is limited to 24/96 though.
Mike
InfernoSTi
« Reply #5 on: 23 Jun 2012, 02:53 pm »
james
It is a function of the output connection.  USB is 192K capable while TOSLINK (optical out) is limited to 96K.
Best,
John
EDIT: Hahaha!  Mike beat me to it!
modad1
« Reply #6 on: 23 Jun 2012, 03:53 pm »
Pure Music does 24-192, sounds really good and is much less expensive than Amara.  You can download it free to try for a couple of weeks before you have to buy it.
Marius
« Reply #7 on: 25 Jun 2012, 10:56 am »
Hi James,
Audirvana (+) does, as long as it its attached to a dac that does....
if not it resamples with Izotope src:
even does dsd..
Marius
Marius
« Reply #8 on: 27 Jun 2012, 02:42 pm »
any luck so far James?
care to share your thoughts/experience?
Marius
« Reply #9 on: 27 Jun 2012, 03:50 pm »
Marius
The only issue so far is I can not get the sample rate to change automatically.
james
Marius
« Reply #10 on: 27 Jun 2012, 05:14 pm »
Sample rate change is a known 'issue'. Bitperfect ought to take care of that, as would Audirvana+. Did you try those?
Marius
« Reply #11 on: 27 Jun 2012, 05:22 pm »
Marius
Hi Marius,
Going to try Audirvana next.
james
jjc1
« Reply #12 on: 27 Jun 2012, 05:30 pm »
  Hey James! Ever heard of the BDP1????????
modad1
« Reply #13 on: 27 Jun 2012, 05:32 pm »
Pure music does automatic sample rate switching.
« Reply #14 on: 27 Jun 2012, 05:48 pm »
james
« Reply #15 on: 27 Jun 2012, 05:49 pm »
Hi,
Yes I have - it is my reference :thumb:
I am trying some of the USB interfaces so need to use my laptops USB out to try the different units and want to make sure I can do 192/24.
james
Marius
« Reply #16 on: 27 Jun 2012, 05:58 pm »
of course you would need some of those units, since the BDA1's Usb input doesn't support 192/24. Might  you be testing  a possible hardware upgrade to the BDA1?
Marius
MArius
Hi,
james
« Reply #17 on: 27 Jun 2012, 06:05 pm »
Marius
MArius
Hi Marius,
We are looking at that but I also wanted to compare against the BDP-1 and see if I could detect any major performance differences. :scratch:
james
Marius
« Reply #18 on: 27 Jun 2012, 06:36 pm »
Ok, great. Let us know your findings.
Marius
