0 Members and 1 Guest are viewing this topic. Read 30414 times.
I have no doubt that servo-controlled systems can reduce measurable distortions quite a bit, but 20db is a large reduction..... assuming all other factors are also considered with a relative comparison to a non-servo-controlled system.
It's Genesis advertising copy. Of course they would tout their superior performance and claims. You may want to re-read my sentence about the X10 reduction. I said "all other things being equal." That means if say, two identical woofers were utilized...you stayed within Xmax....same box....etc, etc, one with a properly implemented servo-control system and one without were used, then a X10 reduction in distortion would not be possible. I don't believe that's an untrue statement.Maybe you can find/quote some other advertising copy that disproves that? Anyways, if it's so much better a solution, then your original query is very apt. Why do you think there aren't more available?I believe the question has already been answered in this thread. They're too complicated and too expensive for the relative performance gain. Just my opinion.Cheers,Dave.
http://forum.audiogon.com/cgi-bin/fr.pl?bhome&1325025368 "If a pair of 12" Rythmiks weren't well under half the price of a pair of 12" JLs, I probably wouldn't have gone there either - home trial or no home trial. Buy, unpack, set up, evaluate, re-pack, re-ship a big ass box...maybe not. However,.....Once I decided to commit to quality subs in my system, I auditioned a sh*tload of subwoofers (most on more than one occasion) over the course of 12-18 months. The results of those auditions varied widely (as did the quality of dealer demo). The variability of subwoofer set-up care, demo system, demo room, etc. really hindered my ability to reach confident conclusions re: relative subwoofer performance, model to model. At the end of the day, I thought that the JLs were the best of the lot"
One think with Rythmik's is that you can buy the pieces and DIY you own (what I did), but in that case you have a one off, and the quality of your Rythmik depend on many factors.
The binding posts - they make all the difference.
