I hope you will be satisfied with your 'Jamos'. Regarding Alpha15s and Beta15s there are evidence that the Betas sound more articulate and clearer than the high Qts Alphas as I posted above.Alpha15 has Fs = 41 Hz and Qts = 1.26 and Beta15 has Fs = 35 and Qts = 0.58. Mostly (in OB) you have to cross from bass to midrange about 200-300 Hz were in fact you will cover a lot of instrumental and voice fundamental tones in the bassrange. I have used Alpha15, AE IB15 and A&D R1524. I cross at 277 Hz sharp between bass and midrange and to me the difference between AE IB15 and Alpha15 is like Night and Day, like you pull a veil from the speakers. I have no experience with the Beta15 but others say they are that better than the Alpha15.But Alpha15 bass superiority is a bit of a myth. Simulation of the units on a 40 x 20 " baffle, two of them placed about the same as on your Jamo baffles looks like this:Alphas first, crossed at 200 Hz 2nd order L-R:Betas, crossed at 160 Hz, to give the same SPL level as the Alphas, 2nd order L-R:So what is the main difference. The Betas may be about 3 dB down compared to the Alpha at 40-50 Hz in all other frequencis they will be more or less equal.This is the trade-off then, some dBs in the very low bass instead of overall clarity and articulation./Erling
I am having a hard time coming to grips with it just being a driver issue, the T/S parameters should be fairly consistent but what people are hearing seems to be totally different.Martin
That is a very biased review of the two drivers presented by a manufacturer with a definite interest in the final conclusion.
I completely understand the conflict of interest introduced by the context of that test. However, I am having a hard time seeing where in the test results any bias could be introduced. John does a pretty goid job identifying the qts spike at 70hz which is probably the muddiness many people hear. This would especially be applicable for those using passive crossovers. Of course, a grain of salt should always be taken with "competitor testing" but I think the numbers speak for themselves. Your thoughts?
One possible explanation would be an amplifier's damping factor, particularly with LF drivers that have weak motors and a corresponding high Qts. An alpha in a system with a high damping factor will likely sound much different, due to the amps ability to quickly damp undesirable cone movements brought on by the mechanical resonance of the driver, particularly near Fs. I believe the system's damping factor would include a combination of the amplifier's damping ratio as well as any influence brought on by large inductors, etc. in a passive filter placed between the amp and driver. In any event, I too have heard alpha's described by people as being "slow" or "sloppy", for what that's worth.
