0 Members and 1 Guest are viewing this topic. Read 10762 times.
2) Apto wellmade and with thick walls, is old one, before 1970s years, but may need renew it.
3) Good acoustics room is the Golden Rule (Golden Ratio = 1.00 Height x Width 1.618 x Length 2.618) also known as a shoebox, the resonances are smaller here than in other proportions of the room. Square room, or close to L / Long is horrible to listen to music, generates a lot of echo and sound stage is impaired. A listening room of B & W-UK Steyning (Steyning Research Establishment) uses the classical Golden Ratio size 3m x 5m x 8m.
4) Electricity is 220Volts good, it costs the same price per KW / Time 127Volts and has more voltage and current.
7) Wiring good is thick wire (hard wire, AWG10 or larger), stranded wire is not suited for building as we know.
9) My city is very humid and ground apartament and 1º floor has more humidity than hi floor, it can mould some CDs, etc., but if you have a tubed amp the prob is solved.
11) Small room can be great good if your amp is a small tube amp and you use a full range speaker.
10 A radical solution to end the Small Room prob I evaluate for some years, is to buy or rent a room in a small business building. It also eliminates the neighbors prob. However is necessary to speak with the building manager on schedules, weekends, read the bylaws, the convention of the condominium and of course take a look at the building transformer. And you still get rid the naughty wife factor.
Gauge does not equate to good sound. Huh? A tube amp will solve 1st floor humidity probs? SMALL TUBE amp to solve small room problems??? Really??? The room is still there no matter what amplification you use. Room Problems = Equipment Position + Seating Position + Room Treatments.
12 meters squared is considered small??? How tall are ceilings???
I think it's a great idea for a little subset club, maybe we should propose a child board.
It could be, if enough traffic would warrant it. Not sure if it would get enough. And with the Acoustics forum, room size, placement, and treatments are already covered. What else would make this forum worthy or different from Acoustics??
Gauge - as long as u meet code...no need to go larger just to go largerA Tube Amp as a dehumidifier?12 meters squared is considered small??? How tall are ceilings???
