I actually have thought about using some sorbothane products under all of the gear in this system. I just never really followed through with it. I might have to look into that option again. Are you suggesting isolation devices specifically for the VDA-2 or each piece of gear to remedy this problem?
Add the VAC-1 Power Supply. It makes a very nice difference.
I don't want my title to give a negative opinion to the VDA-2 as it is a really nice DAC, I am just trying to figure out how to get my system fine tuned with it. A couple of months ago I picked up a VDA-2 as it had some great reviews. I also picked up a Grant Fidelity DAC-11. Each has their own benefits, but one has to go. I find that while the GF is a really nice unit, the VDA-2 has more detail, punch, separation and sound stage. It also is a bit more forward and can have a nice intimate sound. "So what's the problem?", you ask. Because it is a bit more forward and has a nice punch to it, it can be a bit fatiguing to my ears at times. The GF is a bit more relaxed which I attribute to the tube. It is very close, but lacks ever so slightly in the above mentioned categories. My goal is to try and find a way to maintain the positive attributes of the VDA-2, but reduce some of the fatigue. The advice I am seeking from people here is how can I go about doing this. It is connected to a tube integrated Antique Sound Lab amp. The GF is a lot of fun to listen to, but I can tell the VDA-2 is the better unit so here are some thoughts I have:Change tubes in the ampAdd the external power supplyAdd additional thickness to my wall treatmentsDifferent interconnectsWhat do you guys think or what other options do I have?
My experience has been that the power supply results in a significant improvement in the sound. This has also been the case with Dusty's PS for the Logitech Touch.
Is one of those improvements smoothing out the sound?
Interesting comment about the power supply. I have seen in various threads that people say it is worth it to add it and that it improved the DAC. I guess everyone's idea of improved is different.
There's only so much "improvement" replacing an AC source will get you - all the rectification and smoothing is done in the VDA-2 itself - the rest is just (in my opinion) placebo.
What is your source of information which says that the rectification is done in the VDA-2? I don't think that is the case but I will let Dusty comment.
Although there may be a number of third-party power supply vendors selling questionable power supply upgrades, as this is manufactured by Channel Islands as an upgrade for the VDA-2, it sounds like you're saying that Channel Islands is selling a "placebo" as well.
It's certainly possible that in a particular situation, a better AC transformer and filtering could provide a cleaner, clearer sound that some people might find less fatiguing in their setup.
