0 Members and 1 Guest are viewing this topic. Read 11823 times.
why is your sub crossed so high
Would any of the VMPS bass drivers fit into the cabinets? I have no idea if the calculations work for the size of the cabinet but can't you play around with stuffing to 'alter' the cabinet volume? I would say the drivers in my 626's hammer out some serious bass.
Unfortunatley, adding more drivers driven by the same source will not increase the spl unless you have an unlimited supply power amp and you wire them in parrallel. I think
Could it be that he expects wall shaking bass at moderate volume level? Maybe has bad acoustics.
I wish I could invite you all over to hear what I'm talking about.QuoteCould it be that he expects wall shaking bass at moderate volume level? Maybe has bad acoustics.Maybe he expects realistic bass at ANY volume level. Why is it that when I say the bass is lacking people jump to the conclusion that I am looking to rattle the nails out of the walls playing gansta rap? Weak bass means weak bass, it doesn't mean "bummer, why can't I make the neighbor's dishes fall out of the cupboards!"Maxcast: my living room dimensions are 14x12x7.6' But those are not entirely accurate because there are three openings in the room that open into the kitchen and hallway, so add another 10 feet onto the width. This is a problem in itself overall, but not so much that I think the room is doing the speakers a disservice. The bedroom is a bit smaller and narrower. I'd have to measure it, but it's approximately 10x14x7.6' I have concrete floors, so maybe that is weakening the sympathetic vibrations.Well anyway, thanks for all the suggestions. I will stick some different drivers in there and see what happens. Perhaps the 6.9 cabinet would be better. I'm still curious why the visually smaller 6.6 has 10 liters more volume than the 6.9. Is the site info correct Mr. Barnes?
Two other things, one, you are giving us the readings at your listening position, room reflections included. This may or may not be representitive of the speaker, just how it sounds at your listening position.To appropriatley measure the speaker you should measure it from 1 meter.
