Decware vs. Sophia Electric in the low-cost amp category?
0 Members and 1 Guest are viewing this topic. Read 7991 times.
tybee
Re: Decware vs. Sophia Electric in the low-cost amp category?
« Reply #20 on: 14 Jun 2012, 02:42 am »
I have a Mini Torii and prefer E80CCs rather than 12AT7 or 12AU7.  Good balance and bass is very good.
nature boy
« Reply #21 on: 16 Jun 2012, 09:25 pm »
Ok with either the Decware or Sophia Baby as long as you have fairly sensitive speakers.
NB
Equote author=Quiet Earth link=topic=107269.msg1100920#msg1100920 date=1339595022]
Since you have both, can you tell us how they perform driven by an I-pod vs. a CD player?
Does the Zen have enough gain to work with the weaker I-pod signal?
[/quote]
michaelhigh
« Reply #22 on: 16 Jun 2012, 11:00 pm »
I have the Zen Triode Select and Klipsch Forte/kg2 combination (the Decware loves low low impedance, I'm running 2 ohms a side. That's the way it was designed to run!). Fortes alone is fine. :green:
