White light in vacuum tubes?
0 Members and 1 Guest are viewing this topic. Read 893 times.
nathanm
« on: 25 May 2004, 08:31 pm »
What causes a tube to glow with a bright, white light?  I had this one tube (since replaced) which, when the amp was first turned on, would flash very brightly and then die out, start to hum a bit and then flicker a bit more.  I didn't keep it in there very long after that, but I was just curious what is occuring when that happens.  The tube was a KT-88.
Dan Driscoll
Re: White light in vacuum tubes?
« Reply #1 on: 25 May 2004, 11:31 pm »
Quote from: nathanm
An instantaneous white flash sounds like an arc.
nathanm
« Reply #2 on: 26 May 2004, 02:30 am »
What's arcing though?  Is there something that's broken, some pieces that are touching inside there that shouldn't be?
Dan Driscoll
« Reply #3 on: 26 May 2004, 09:05 pm »
Quote from: nathanm
Assuming the tube functioned properly for a while, then something probably broke. The windings on the grid and plate are pretty small and turn-on shock can cause them to break, especially if the tube has been well used.
