here is an excellent video that spells it all outhttp://www.youtube.com/watch?v=ayOXz26qm3I
I have a question regarding the multiple sub concept. If your main left and right speakers already go as low as many subwoofers go, then shouldn't you count the mains as the first two subs that you already own? For example; if I add a single sub to a full range pair of speakers, I would effectively have 3 subs. If I add two subs I would effectively have 4 subs, and so on. Does that sound right?If this is not correct, please explain why not.
To obtain the best possible LF response…boundary interference issues can be tougher to address. Varying the fixed distances from ‘speaker to boundary’ and ‘listener to boundary’ will reduce strong cancellations. It is a balancing act as one location that may offer a smoother LF response may not provide the optimal midrange and treble response…” (emphasis added) and “…everyone desires a ‘flat’ LF response and no modal ringing. Simply, this is a tough achievement. The absurdly large collection of interrelated variables between two fullrange speakers and the room (speaker design, speaker/listener location, room size/construction and acoustical control within) makes this so. It is up to the individual to determine what their limits are as regards placement and acoustical treatments…
Meh. It's not quite that easy. It takes a bunch of time and patience. I suggest you read Dr. Geddes' paper.
I will. I've been reading this sort of material lately. But this guy's advice seems like a solid place to start: 4 subs placed in the middle of each 4 walls, mono, in phase.
…in principal the multiple subwoofer concept, as realized in the Audio Kinesis (Duke LeJeune) Swarm system, should work better than the single sub that I was using-I hope to try that system later...
Swept Sine Waves, 0 dB = 60 dB with mic @ sweet spot. etc...
Speed of sound 1100fps/70 Hz = 15.7' wave
' wave x 2 = 31.4' for one complete (audible) cycle.
Have you ever seen anyone promoting EQ post before/after results other than the sweet spot?
Do you think the modes existing between the listener and speakers have no effect on spatial performance, nor phase relationships above the Schroeder frequency?
Do you have any links or references on this? Thanks
