Do you think i will get even beter results with a PSI USB card (SOtM) ? Or is that not necessary anymore ?http://www.mediaelectronics.be/shop/nl/579-sotm-tx-usbexp-audiophile-pcie-to-usb-audio-card.html
Beyond the rave, I do have a question. I've read that, when using USB for audio, it's a bad idea to use USB for anything else. Does having other, simultaneous activity on the USB bus adversely impact the performance of the Transient?Thanks,Keith
In theory, DAVEBSC is correct. However it really depends if the extra work being done by the computer is causing any audible degradation.I use Transient with both a MAC and Win PC. Both have external SSD's connected by USB, and have had no issues with drop-outs or audible signal degradation. It is very system dependent as computers vary in hardware, power supplies, controllers etc. It's best to try different configurations and judge for yourself.
I ordered the sound card, i will let you know I also played more with and without the power supply, and the differences are quite big.It really shines with the power supply, the bass is much stronger, certainly an improvement.
I think it is what it is, the converter works fine when i use another USB port from the same PC.
Dusty, is the USB converter also compatible with Linux software (Vortexbox) system ?
