Meet 6/23 at richidoo's
0 Members and 1 Guest are viewing this topic. Read 17652 times.
richidoo
Re: Meet 6/23 at richidoo's
« Reply #40 on: 25 Jun 2012, 06:26 pm »
We had fun. Come to the next one if you can.
Playing with the Polks some more this morning, I tried a 2ohm resistor in place of positive jumper, sounds just about right to me.  But they really liked that NCore amp on the bass - I miss it already! Anyone who would like to hear the Polks is welcome to stop by.
jtwrace
    • TIPP YouTube Channel
« Reply #41 on: 25 Jun 2012, 06:41 pm »
You too can have a pair.   :P
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #42 on: 26 Jun 2012, 06:44 pm »
I know there's some interest in comparing the Cherry and Ncore amps. A good place to start would be here http://www.audiograph.se/standalone.html
This unit will tell you quite a bit how the amps will perform into a real world load. Subjective comparisons are sketchy without control of all the variables and keeping listening levels the same.
jtwrace
« Reply #43 on: 26 Jun 2012, 06:55 pm »
Yes, objective data can be seen here http://www.hypex.nl/docs/NC400_datasheet.pdf and AC's very own mgalusha did an FFT plot on his $10k tester here http://www.audiocircle.com/index.php?topic=107040.msg1097394#msg1097394
Rick Craig
  • Selah Audio
« Reply #44 on: 26 Jun 2012, 08:05 pm »
Thanks for the information. The Power Cube takes things a little further though so you can see how the amp deals with a reactive load. Actually the Ncore might do quite well since it performs well in the standard tests.  What commercial designs are using it in amps on the market?
richidoo
« Reply #45 on: 26 Jun 2012, 09:56 pm »
Rick, the NCore 400W model is intended for DIY use only. They also make a 1200W NCore unit for OEMs.
richidoo
« Reply #46 on: 30 Aug 2012, 07:56 pm »
Post for testing the favorites tab on homepage.
Carolina Audiophiles please set this circle in your favorites list!
jtwrace
« Reply #47 on: 30 Aug 2012, 07:58 pm »
I was thinking you were already planning the 6/2013 meet.   :lol:
richidoo
« Reply #48 on: 31 Aug 2012, 03:16 pm »
Hopefully sooner than that!  :thumb:
