SA-1 amps
0 Members and 1 Guest are viewing this topic. Read 1603 times.
mikeeastman
SA-1 amps
« on: 21 May 2012, 02:41 am »
i'm going to build a sub using a dual voice coil driver, it's rate for 250 watts @ 4 ohms per coil. Can I use two SA-1 amps, one powering each coil?
Danny Richie
Re: SA-1 amps
« Reply #1 on: 21 May 2012, 03:04 pm »
I don't think I'd try that, and I am all out of SA-1 amps.
mikeeastman
Re: SA-1 amps
« Reply #2 on: 21 May 2012, 03:15 pm »
I have the amps, why are the reasons you won't try?
  Thanks, Mike
Nick77
Re: SA-1 amps
« Reply #3 on: 21 May 2012, 05:19 pm »
Danny is the SA-1 discontinued or just out of stock?
Danny Richie
Re: SA-1 amps
« Reply #4 on: 21 May 2012, 05:24 pm »
Mike,
If you are going to try to control one woofer with two amps then be sure that the amps are getting the same signal. If you send one a left channel signal and one a right channel signal then at times each amp could be trying to control the woofer in a different way, fighting each other.
Nick,
I am not having any more SA-1 amps made.
