Y-connector for summing signal. . .bass only???
0 Members and 1 Guest are viewing this topic. Read 4534 times.
pjchappy
« on: 24 May 2004, 06:40 pm »
What would be the problems w/ using a Y-connector to sum a 2-channel signal. . . for subwoofer use only.
p
Marbles
Re: Y-connector for summing signal. . .bass only???
« Reply #1 on: 24 May 2004, 06:56 pm »
Quote from: pjchappy
p
Describe exactly how you would do it.
pjchappy
« Reply #2 on: 24 May 2004, 07:01 pm »
Either from my 2-channel output from my CD-player, or from the pre-out of a future integrated. ..the Y-connector would then be connected to another interconnect.  This interconnect would then go into 1-channel of my QSC amp. . .the amp would then be put into parallel mode (same signal in both channels), then bridged. . .then speaker cables would go to my sub.
Is this exact enough?   :P
p
electricbear
summing for sub
« Reply #3 on: 24 May 2004, 07:40 pm »
I have tried this at the store and with some products I have found that it makes everything mono.I  tried to y out of thepreout on an integrated to run a sub and it caused the speaker outs to go to mono.
rosconey
« Reply #4 on: 24 May 2004, 07:57 pm »
do it the easy way and just buy another sub- :lol:
pjchappy
« Reply #5 on: 24 May 2004, 08:09 pm »
I would LOVE to. . . . but, I am po. ..
p
Rob Babcock
« Reply #6 on: 24 May 2004, 08:16 pm »
Does the QSC have a low pass built in?  The main problem I could foresee with such a setup is that the sub amp would get a full range signal- you wouldn't want that playing thru the sub!
You'd need multiple Y's to do with with a CD player:  first a Y at the CD output to convert the L & R into two jacks each.  Then a Y & in reverse to sum on pair to mono for the sub.
If you're amp has an X-over, such a thing could probably be made to work, but I doubt it would be ideal.  Seems to me going thru all those adapters may either degrade the sound or allow some hum/RFI into your system.  And it would depend how flexible the X-over was in your amp.
A better bet would be to pick up a cheap outboard X-over instead.
rosconey
« Reply #7 on: 24 May 2004, 08:26 pm »
you could try the behringer 2channel crossover at parts express for 89$.
has a  single sub out , i think its xlr though.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=248-664
pjchappy
« Reply #8 on: 24 May 2004, 08:37 pm »
Rob,
1st off, my sub has a 90hz low-pass. . .so, that is no problem.
Secondly, I wouldn't need as many connections. . .the QSC amp has a parallel mode, which puts one channel of input and makes the same signal in the other channel (it does not SUM, though). . .then, I use it in bridged mono mode into my sub (the subs low-pass will deal w/ that full-range signal). . .
Soo, here is what it would be like:
CD-L........CD-R
..I..............I
..I..............I
.....I........I
.......I.....I
..........Y
.......Amp (parallel mode; bridge-mono mode)
........I...I
........I...I
........I...I
........SUB (w/ low-pass)
(spaces don't stay spaced)
Would this work?  What would be the problems w/ a Y?
And Rosconey, I used to have that exact thing. . .I sold it (I shouldn't have. . .). . .The thing is, all I need is to sum the signal. . . cheaply.  That would basically be a waste as I would not use 90% of its features.  I might have to go that route, though if this is a bad idea above.
p
scottnixon
    • http://www.scott-nixon.com
« Reply #9 on: 24 May 2004, 11:40 pm »
You'll need a couple of resistors to sum the channels without monoizing the setup.  I've used a couple of 39k to 50k , just add one in line with your cd R/L out into the mono'd/summed output.
pjchappy
« Reply #10 on: 24 May 2004, 11:43 pm »
So, monoing would be the only problem?  It is going to 1 sub.  Also, it would be coming out of the CDs analog outputs.  I would use the digital output into your TubeDac+. . . this configuration wouldn't mono the digital, too????
Anyways, I may just go the more expensive route. . .can always sell it off when I don't need it. . .also, I think I may start a job in the next couple weeks.   :wink:
p
audioengr
« Reply #11 on: 25 May 2004, 01:22 am »
Sorry - bad idea.  The output drivers from your players or preamp will drive into each other.  If they are low-impedance, damage could result.  The best solution is a buffered summing device that does not load or otherwise compromise the front channels.
I have such a device in prototype phase.  I need to drive my sub from both my 2-channel system (mixing left and right) and also from the HT system (from the SS processor sub outputs.  This device will do this.  It plugs into the L and R outputs of your preamp (has short cables attached)and then provides jacks for:
L out - to amp
R out - to amp
SS processor sub in - from SS proc.
sub out - to powered sub or sub amp
The gain difference between the HT and 2-channel system is set by first adjusting the powered sub volume for the 2-channel system. Then the HT sub volume is adjusted at the SS proc. along with all of the other surround channels.   If you use a sub amp, then a separate gain control is needed for the sub output.
pjchappy
« Reply #12 on: 25 May 2004, 01:23 am »
Damn. . .
Looks like I'll buy that Behringer x-over. . . never should have sold it.
p
audioengr
« Reply #13 on: 25 May 2004, 01:26 am »
Too bad that ALL crossovers seem to kill the sound of perfectly good systems. I've modded some of these lately...
pjchappy
« Reply #14 on: 25 May 2004, 01:29 am »
I just can't believe there isn't a little box that would do this for me. . .the Behringer does WAY more than I need.
p
audioengr
« Reply #15 on: 25 May 2004, 04:39 pm »
There was a little box.  It is the Snell active crossover.  It is not too bad without mods, but can get better.  I just sold a modded one to a guy in the Virgin Islands.  You might try ebay or audiogon.  The thing was $300 new.  I'm sure they dont sell it anymore though.  Until I come out with my sub buffer  I'm not aware of anything cheap that is new.
