Neo 6
0 Members and 1 Guest are viewing this topic. Read 1204 times.
Mag
Neo 6
« on: 18 May 2012, 11:48 pm »
I've been using Neo 6 a lot lately with my SP2. I find that I'm hearing more instrument & channel seperation & detail particularly in the higher frequency range. This is with basic stereo cd which is dts matrixed into 6 channels. Getting the center channel calibrated right is key to getting it to sound right.
Dolby Pro Logic II sounds good but I rarely use it for music. Because in my opinion it flattens out linears highs, which is the attribute of the SST2 amp, which I like. So why would I want to flatten it out?
Anyway if you're using a multi-channel processor give Neo 6 a try. 8)
Mag
Re: Neo 6
« Reply #1 on: 19 Jan 2013, 09:57 pm »
Ok, the SP3 has been out for awhile now, any Neo: 6 music listening converts yet? :smoke:
Mag
Re: Neo 6
« Reply #2 on: 20 Jan 2013, 05:24 pm »
For those of you who are not familiar with Neo:6. I find with my unconventional speaker set up, Neo: 6 to be almost the same as regular 2 channel stereo, except it has a little more body or texture for lack of a better term. I can switch from 2 channel bypass to multi channel Neo:6 on the fly.8)
