Does it exist?
0 Members and 1 Guest are viewing this topic. Read 8390 times.
Papajin
Does it exist?
« Reply #20 on: 14 Jul 2005, 01:07 pm »
Not quite what the original poster was looking for, but might still be of interest for someone out there:
http://www.atechfabrication.com/products/mass_storage.htm
JoshK
Does it exist?
« Reply #21 on: 18 Jul 2005, 03:32 pm »
Yeah, I saw that the other day.  Their Heatsink HTPC case is truely awe inspiring, but $1000 for a case!?!  :o  I am going to knock off a DIY version of this case when my project list allows for it.  I also have a couple ideas for improvements to the design.
FWIW, a great resource on silent computing for anyone thinking of doing audio or HTPCs is silentpcreview.com.  They have a forum as well and tons of reviews with silence as the key issue.
I built a linux file server (just installed Red Hat 9.0 last night actually, it was a breeze).  My plan was to have all the noisey HDs elsewhere located, in this case, in the basement.
brj
Does it exist?
« Reply #22 on: 18 Jul 2005, 06:48 pm »
Welcome to AC, Papajin, and thanks for a great link!  Somehow, I had missed that company in my HTPC related surfing.
Quote from: JoshK
I configured one and hit roughly $1100 with all of the passive cooling devices added.  This is definitely not cheap and much higher than I would like, but it seems inline with other similar cases (solid aluminum construction with fully passive cooling via heatpipes).
Quote from: JoshK
You have a less expensive source for (mostly) billet aluminum cases?  I'd definitely be interested in learning more about it.  I plan on going this route at some point, but there seems to be rather limited availability of passively cooled cases that look like audio components.
Quote from: JoshK
I'll second that recommendation.  They are an excellant source of info on quite PCs.
Quote from: JoshK
Good idea.  (Wish I had a basement!)
I'm risking a detour off topic here, but why RH9?  It was end-of-lifed a year ago this past April, so you can no longer get patches or security updates.  In addition, the 2.6 series kernels are definitely higher performing that the 2.4 kernel in RH9.  (My home desktop machine has a RH9 partition and a Windows 2000 partition, but I almost always boot into my SuSE Pro 9.3 partition.)
JoshK
Does it exist?
« Reply #23 on: 18 Jul 2005, 06:57 pm »
I chose RH9.0 because I got it free, my IT guy gave it to me after they decided against it as a trial.  I had heard it was easy to install and this was my first linux install.  It was darn easy, as easy as an NT install IMO.  I didn't know it was EOL'd.
Ultimately I wanted to try out a couple of distros before I commit to one for a HTPC I have planned (mythTV based).  Gentoo supports 64bit operation, and AMD 64 seems like the way to go right  now.
