I'm sure Jim can confirm this, but when I had my SongBird apart to replace the damaged woofer, the internal wiring looked anything but cheap. Quite heavy, in fact, but I don't know the AWG.Cornelis
Now that just seems silly. No way changing a power cord on your amp and pre-amp are going to significantly lower the impedence of your whole house. Are you changing all the wires going to your AC also?I could see how a power conditioner could make a difference and it may then make sense to use an upgraded cord from the conditioner to the equipment.
Regardless of what explanation makes the most sense, why not just give these things a try in your own system? Simple enough to do, as I keep mentioning.
I guess I know too much about science. I don't have time or patience to do a proper DBT.
I'm putting my upgrade money into speakers.
But lets hope your comments don't discourage others from trying out cables, etc with the gold standard double blind method.
I am not talking one cable but outfitting the entire house. Outfitting your system with better mains leads will lower the impedance off that circuit into your fuse box only. How much it effects what your neighborhood transformer sees is another question. It probably does though. I am using a 240 20 amp service into my gear and it's glorious. Best kept secret in hifi is 240 into 20 amps.
There is improvement that we hear and can explain, and there is improvement that we hear and can't explain. But both are worthwhile if you are hunting for the best sound.
Now that does make some sense, but I'll bet most people don't bother to go that extent. They'll use an upgraded power cord off a regular wall socket that's cabled with who knows what, without a power conditioner, I don't see how the last two feet can make any difference.
. It doesn't take much to research the appropriate geometry and construction methods and build superior cables for very little money. And it is interesting how many cables don't bother to follow those simple design parameters.So IMO it is true the cables are important and can make large differences depending on the system and sensitivity of the listener, but it is related more to the cable's construction rather than price.
Q: Why does your cables "sound better"?Cable Manufacturer: I don't know. I can't explain it.
Thanks for all the comments.This is what I'm going to do. Hold on cable/IC upgrade for a few months. First get used to my ST-RT sound and then order the cables. If I see a significant difference, good for me. Else, I don't belong to that elite club!
Truer words have never been spoken.Sorry if I offend anyone but its simply snake oil. When you have hobbies like these where literally everyone in the hobby obviously has disposable income then a company will always pop up to try to get some of it.The other obvious example is golf. Golf isn't exactly a sport for poor folk and the golfing industry is LITTERED with ridiculous gadgets and gizmos that have a 1000%+ mark up that people buy all day long.Who among you think this is a good buy?http://app.audiogon.com/listings/harmonic-resolution-systems-3-shelf-rack-system-19-x9,000 for a component rack?
There are very few high $$$ components or systems that are worthwhile, IMO.... but just like anything else, it is a diminishing return on investment and lots of folks aren't concerned about how much money things cost. So for those of us on a budget, it's difficult to understand paying 10x as much for something that isn't that much better.
Oh, I think paying 10x more for gear (particularly in the case of speakers) is a case of diminishing returns. Wow do some speakers that cost 10x more than mine just blow my speakers out of the water. And I love my speakers. Likewise there are speakers 2x or 3x what mine cost that are also very clearly better sounding in almost all respects.
