NEW for 2012! Revised 100 watt tube monos
Niteshade
    • Niteshade Audio
« on: 15 May 2012, 12:29 am »
100 Watt 6L6 tube mono blocks
These amps are formidable. Plenty of power, extremely low noise output and resolution you would expect from a Niteshade amplifier. Think of these as an extension of the NS-40. If you have read about the NS-40 or own one, these sound exactly the same except there is 60 watts extra per channel. Easy on the tubes? Absolutely!
Features:
Edcor Transformers
Oversize power supply
Mark III circuit improvements
IEC power socket
Custom, hand built chassis
Point to Point wiring
Computer grade capacitors
The most streamlined circuit on the market
What can be added?
Wood sides or wrap
Custom paint job
Custom transformer finish
DC Filaments
Much more is available too!
« Last Edit: 28 Jun 2012, 11:23 am by Niteshade »
dangerbird
Re: NEW for 2012! Revised 100 watt tube monos
« Reply #1 on: 15 May 2012, 03:35 pm »
for a moment,,I thought they were mine.  :D
Niteshade
    • Niteshade Audio
« Reply #2 on: 15 May 2012, 06:19 pm »
These are the first 2012 100 watt monos with all new components. Yours are coming up shortly. I recently completed this design and it came out terrific!
djbnh
« Reply #3 on: 16 May 2012, 07:24 am »
Any chokes used or required?
Niteshade
    • Niteshade Audio
« Reply #4 on: 16 May 2012, 09:42 am »
All my tube amplifier designs do not require a choke in the power supply. I like to use them in my classic designs. Back in the 40's and 50's they were necessary because most filter capacitors were too small to eliminate ripple in the B+ by themselves.
If someone wanted a choke based power supply, I would be happy to accommodate.
