Scotty,
The brand of phono is Aqvox, it has dip switches inside to disable all the caps. I could "Turn them on" I hate to do it due to the incredible transparency without them, and of course I don't want to upgrade them all if I don't need to use them.
Aqvox does warn "Some manufactures" preamps etc... might not like running the phono with no output caps, but again its a passive, and I know I am cutting dc at the input of the amp anyway with no reason to worry about it now. But if I put this amp in, I am not 100% sure what the possible outcome is if there are no caps at the XLR inputs.
NO the amp manufacture does not warn against dc, as a matter of fact its the opposite as an upgrade path available from them they actually completely remove the input caps as part of a whole circuit change. However, my case is obviously a little unique in that I can bypass the caps in the source(phono stage) and also running no caps all the way down thru the passive direct connection into the amp.
So its a crap shoot I think, as many manufactures such as krell that I have spoken with in the past also think you normally will not need any dc coupling caps, but again I don't know that they are accounting for passive preamps, and devices with their own caps lifted in the first place as they think everybody builds their gear mostly with output or input caps so no need to double up putting more in the way on every component.
As stated above, maybe the autoformers in the preamp will block dc from passing anyway, I have a good source to call and find out I believe, but would have to do that on Monday.
