New Dipole Project using GR drivers
0 Members and 1 Guest are viewing this topic. Read 2962 times.
ttan98
« on: 11 May 2012, 02:46 pm »
Danny,
I thought you may like to know I have completed a Open Baffle True Dipole project based on GR drivers except the twin woofers. The speaker configuration is TMMWW, refer to images attached.
T - T3
M - midrange M130
M - Mid woofer M165X
W- Eminence  Driver similar to those use in V2.
For further details refer to True Dipole Project under the "Open Baffle Forum".
nickd
Re: New Dipole Project using GR drivers
« Reply #1 on: 11 May 2012, 04:52 pm »
Nicely done,
Are you thinking about active EQ or gain for the woofers? looks like they need some boost unless you have enough in room gain. I really like the sound of OB bass. Why you decided to build a box for the 12's :scratch:
ttan98
« Reply #2 on: 12 May 2012, 05:22 am »
Nicely done,
The "box" for the woofer is actually a U-frame, i.e. open back. 2*12" woofer gives very high efficiency, and I have reduce the overall gain via the Behringer or the reduce the volume gain from the woofer amplifier.
