Norh CD-1 is frying bacon
jqp
« on: 9 May 2012, 02:57 am »
My nOrh CD-1 was skipping when playing CDs. I turned it off and it seemed to have corrected itself. Then it started doing it again. Then it made the sound of bacon frying - static noises.
Hopefully it is just a tube gone bad - tonight it goes under the knife for replacement of the two output tubes, 12AX7.
Also while I am in there I will clean the transport assembly with dust-off canned air.
jqp
Re: Norh CD-1 is frying bacon
« Reply #1 on: 9 May 2012, 04:41 am »
New tubes are in and it's as good as new, so far.
jqp
« Reply #2 on: 9 May 2012, 04:46 am »
CD-1 (QDS-15) motherboard with the output tubes
the power section
remove tubes
jqp
« Reply #3 on: 9 May 2012, 04:49 am »
old tube on right new tube on left
Is this a problem?
JohnR
« Reply #4 on: 9 May 2012, 08:33 am »
Is this a problem?
It doesn't look great but could just be a botchy repair/rework job. What's the number on the chip?
jqp
« Reply #5 on: 9 May 2012, 06:47 pm »
I will have to get a better shot of the chips - I thought for sure i would have some in focus - need to take the chassis apart again tonight
jqp
« Reply #6 on: 11 May 2012, 02:33 am »
It appears to be [ PCM1728E K9005A ]
... whic his a Texas Instruments DAC
   Audio D/A Converter ICs 24-Bit 96kHz Smplg CMOS D-S Stereo DAC
... and you can read the rest here
http://www.ti.com/lit/ds/symlink/pcm1728.pdf
jqp
« Reply #7 on: 11 May 2012, 02:53 am »
The tubes seem to be burning in just fine
JohnR
« Reply #8 on: 11 May 2012, 10:27 am »
Looks like flux. Is it still "frying bacon"?
jqp
« Reply #9 on: 11 May 2012, 06:54 pm »
No it quit making the crackling static when I changed the tubes - they had been in there over 10 years. The CD-1 was turned on at least 8 of those years 24x7! Not sure what the life expectancy is of the average 12AX7 tube is - another thing, there seemed to be more gain with new tubes?
JohnR
« Reply #10 on: 12 May 2012, 01:24 pm »
I would expect that the tubes are used only as buffers. Like in my old Cal Alpha. Though I never did understand why a 12ax7 would be used there. Anyway, 8 years 24/7 would be... um, 70,000 hours? Pretty good going, but probably well past the replace-by date.
