Just did a line conditioner based on the circuit of Jon Risch. I don't have funds for expensive stuffs.
When I only saw the first photo, I wondered how you were going to get all the parts in that case, but I see that they all fit.For a dis-jointed tread on power line capacitors, see:http://www.diyaudio.com/forums/power-supplies/211946-x-capacitor.html
What RFI insertion loss it provides???? I'd want to know how would it perform before I proceed.c-J
Not really sure if it was stated here.http://links.dalrun.com/Electronics/Docs/Surge_Protection/files/AC%20Filter%20&%20Surge%20Suppresor.htm.
Hi.I can't read any performance specs from yr link.I'd strongly suggest you to mail J. Hirsch to find out. You should know how effective it would be after spending money & times on it, right? Otherwsie, why go thru the excercise W/O knowing the designated results?????FYI, I've installed 3 similar simple linear inline powerline passive filters, each in the 3 dedicated lines for many years now.(1) 125V60Hz (digital gear only, e.g DVD/DVD players), (2) 125V60Hz (hi-current analogue gear only,e.g. tube/SS phono-preamps, tube power amp) & (3) 250V60Hz (analoge gear only, e.g. my tape deck, TT & SS power amp, all 110V/220V, set to 220V).These linear PASSIVE inline filters were imported from England, providing wideband EMI/RFI filtering:- 100KHz to 200MHz & beyond. Max. insertion loss 52dB @ 32MHz, 36dB @ 100MHz.The reason why I have chosen quality PASSIVE linear filters mainly because they do NOT affect the music vs so many expensive brandname conditioners which filter out RFI noises as well as the music!!!! No good!c-J
Great job. I've done similarly more than once. My very first PC came with an accessory pack, one of the accessories was a rather cheap power strip. I converted it to filtered with full three line surge protection and a quick blow fuse. It has served me, protected all my computers well since 1993. I recommend you also add some MOVs.
Thanks bro.Not really keen on those MOVs as the ac power here in singapore is quite stable. Besides base on my reading, it somehow makes the sound of your system a bit rough.
I'm skeptical of those kinds of statements, unless they are corroborated by credible and repeatable measurements. Anyway, MOVs are kind of like seat belts, they only work when things go really bad. Better to be safe than sorry. You'll find that many a manufacturer already has surge protection (MOVS) inside their equipment.Use an LCR meter to measure an MOV and it looks like a capacitor.
Please take note:The use of Mundorf or other non rated X or Y capacitors are not supposed to be used in AC application. Do it at your own risk.
That is correct so why are you doing it?
Now 'Oystein' brings up several good and important points.
