0 Members and 1 Guest are viewing this topic. Read 322646 times.
hi guys, this is my hypex nc400. Didn't build myself.
Hi DaveHow did you get the faceplates screened with Ncore - those look cool.
the case is custom build from profiles:http://www.fischerelektronik.de/web_fischer/de_DE/Gehäuse/M1.05/Kombinationsgehäuse/PG/KO_R2/index.xhtmlhttp://www.fischerelektronik.de/web_fischer/de_DE/Gehäuse/M1.05/Kombinationsgehäuse/PG/KO_H4A/index.xhtml
hello anand,do the cardas xlr's fit into the same size hole as the neutrik? where did you get the toggle switch (part #)?thanks,drmike
Cardas Quad Eutectic Solder used.
And does it make a difference compared to "regular" non-RoHS solder?
If you ask others, they will say it will help sonically, blah, blah. I use it cause it flows easily
I haven't listened to the unit critically yet...I have been thrilled with the stock unit in all honesty. And aural memory sucks for me for the most part. I strongly doubt night and day differences.
Anand, Julf... I also replaced the stock power cable with proper (Belden) cable. I think it's an absolutely essential tweak for every one. The difference is not small.
