General Speaker Question
0 Members and 1 Guest are viewing this topic. Read 1297 times.
SteveRB
« on: 4 May 2012, 05:55 pm »
Just a quick question:
What is this threaded hole on the back of an old alnico woofer for?
Is it a vent?
I was hoping I could use it to bolt a brace to the back of the driver...
Æ
Re: General Speaker Question
« Reply #1 on: 4 May 2012, 06:06 pm »
Is it a vent?
Shine a small flashlight up in there and see if it is a through hole or not. Better yet, put your lips against it and blow. If air blows through, then it is a vent. If it is a vent and you blow hard enough, the woofer cone should move some.
If it is not a vent, then it is some sort of manufacturing hole, part of the manufacturing process.
If it's not a vent, then yes you may insert a screw. I'd suggest using a non ferrous screw. I.E. brass.
SteveRB
« Reply #2 on: 4 May 2012, 06:09 pm »
that's what I was thinking...
Wayner
« Reply #3 on: 4 May 2012, 08:46 pm »
It's part of the assembly process, to align the components of the magnet assembly.
Wayner
