New tweeter compared to others like the Raven, Heil, others?
0 Members and 1 Guest are viewing this topic. Read 6309 times.
cab
Wondering how the new RM/x tweeter compares to other lauded tweeters, like the raven, heil, etc.? Any one have any comments?
Thanks...
fredgarvin
tweeter
« Reply #1 on: 5 Feb 2003, 01:09 pm »
I'd say the tweeter that is hot right now is the Vifa ring radiator. New speaker models featuring the Vifa are popping up constantly. I saw a pic of the new Von Schweikert vr4 se and it looked like the new tweeter there is the Vifa as well.
Brian Cheney
    • http://www.vmpsaudio.com
domes
« Reply #2 on: 5 Feb 2003, 04:34 pm »
"Hot" tweeters indeed.  Moving mass of a softdome or ring radiator is 2-4 g.  Our new free-swinging ribbon is 13 milligrams with outstanding linearity and a very sweet tonal character.  Typical dome sensitivity is 90-93 dB.  Our new tweeter is 96dB.  The design is similar to the Raven with improved magnetics and lower moving mass.  The Heil does not compete.
Q
Re: domes
« Reply #3 on: 18 Feb 2003, 04:25 pm »
I use the Raven R2 in my custom speakers (see e-speakers.com) and they are crossed at 5kHz.  When driven hard they undulate like a leaf on a tree!  I wonder how the new VMPS tweeter will work crossed at 7k?
Personally I thot the spirals sounded better than my Ravens when I listened to the RM40s.  That may have something to do with x-over points/slopes/and sources.  Also, the spirals at least have vertical dispersion....I know the raven is very flat and wide...so dont plan on standing to hear any treble.
Quote from: Brian Cheney
Rocket
raven tweeters
« Reply #4 on: 19 Feb 2003, 09:04 am »
hello q,
i've heard the raven 2 many times and it is a great tweeter.  what are the other drivers your using in your speaker?  did you design the xover yourself?
my speakers are custom built using the raven 1 tweeter mtm with 2 x 7inch focal drivers.  if the vmps tweeter is better then i'm impressed.  i've been very happy with the raven tweeter.  have you torn any of the ribbons yet?
regards
rod
Q
Re: raven tweeters
« Reply #5 on: 19 Feb 2003, 01:03 pm »
I'm using twin PHL 1240 they are special 16ohm 6.5" drivers....pretty new for PHL. See http://www.e-speakers.com/products/phl-mid-woofers.html
 I was told it is one of the few midbass drivers that can reach 5kHz well (which is the xover freq). They arent bad, but between my cabinet and the drivers, I cant seem to get rid of some resonance in the ~250Hz range and there is also a peak in the upper mid.  I did not design the crossover.  It is a kit directly from E-speakers.com via Andre Perrault.  He is great to work with and very helpful.  I did build the cabinets from 1"MDF/oak veneer.  I have not torn ribbons, but three of them have just flattened out suddenly for no apparent reason.  Man is that a pain in the ... replacing a ribbon!!!  At least it is something one can tackle by themselves as tough as it is.
I think part of the VMPS RM40 success is how high the mids are crossed.
I assume your R1 is crossed rather high, and that typically leads to beaming of the upper mids.  And thats really something i didnt notice with the RM40.
Quote from: Rocket
hello q,
regards
rod
Rocket
now i'm impressed
« Reply #6 on: 20 Feb 2003, 12:49 am »
hello,
pat at war audio has designed an mtm speaker using raven 2 and 2x phl 1240 drivers in an mtm configuration it is one of the best speakers i've heard.
i haven't heard any beaming with the tweeter i find it much better than the focal tweeters i've compared it to.  the designer did have to redesign my xover has i kept tearing ribbons, luckily i haven't torn one for 12 months now.
anyway happy listening.
regards
rod
